查看: 41385|回复: 151
Tina v9.0 最新版
发表于 2010-5-1 12:04:54 | 显示全部楼层 |阅读模式
New features of TINA v9 and TINA Design Suite v9
  • Full Vista and Windows 7 compatibility
  • Multi core support
  • Enhanced analysis speed
    Up to 10 times higher speed on 1 core, 15x on dual core, 20x on quad core
  • Advanced powerful Spice-VHDL mixed mode analysis
  • Extended catalog with ARM 7, ARM 9 and HCS08 microcontrollers, more SMPS ICs models, realistic ADC and DAC models, LCD display, Bi-color LEDs
  • Extended MCU simulation, USB and other modules
  • Programmable Design Tool where users can implement design procedures for calculating and setting circuit parameters so that the circuits can produce predefined target output values.
  • Extended flowchart tool: PIC, AVR, 8051, code box, USART, external interrupt handling
  • Open and save TINA designs, models and libraries directly from the Web
  • Import Spice .CIR and .LIB files directly from the Web
  • Import Libraries, Designs and Examples from any earlier versions of TINA v7 and later.
  • Show analysis results on diagrams during analysis
  • Fast diagram drawing and processing speed, even for very large circuits
  • New tool in the View menu of the diagrams for easier hiding and showing curves on diagrams
  • New more effective storing of analysis results, save all analysis results for all circuits without speed compromise
  • Parametrizable output curve filter for even more effective storage of results
  • Scrollbars for browsing multiple diagrams on the same page
  • New diagram cursor tools to find and annotate
    local and global maximum, minimum
    gain and phase margins
    zero crossover frequency
    horizontal and vertical coordinates
  • Combinational and parallel stepping , show stepping cases (test benches) in separate diagrams
  • More advanced tools for addition of parts to TINA from semiconductor manufacturers both from downloaded files and directly from the internet
  • Node list in post processor now displays macro names and local node names in the relevant macros
  • Minimize TINA main window while analysis is running
  • Run two TINA instances on the same computer
  • Multi-level, hierarchical ERC. Checks the main or any subcircuts, or the whole circuit in full depth
  • ERC detects and shows floating nodes in Spice subcircuits
  • Open Examples command in File menu, for easier return to TINA’s Examples folder
  • Open .CIR files from Open command in the File menu
  • New arrow button in Open dialog, for easier finding TINA EXAMPLES or User folders
  • Updated and extended examples under the EXAMPLES folder
  • Conversion of circuits to TINA v7 format, for compatibility with TINA v7 and v8 and v9
  • Detailed Transient Statistics from the View menu
  • TINA v9 is now digitally signed by DesignSoft
PCB Design
  • G-Code export of PCB designs for creating control files for milling machines
  • Extended PCB footprint catalog
Tina90en.part01.rar (4.39 MB , 下载次数: 789 )
Tina90en.part02.rar (4.39 MB , 下载次数: 660 )
Tina90en.part03.rar (4.39 MB , 下载次数: 482 )
Tina90en.part04.rar (4.39 MB , 下载次数: 521 )
Tina90en.part05.rar (4.39 MB , 下载次数: 476 )
Tina90en.part06.rar (4.39 MB , 下载次数: 516 )
Tina90en.part07.rar (4.39 MB , 下载次数: 503 )
Tina90en.part08.rar (4.39 MB , 下载次数: 510 )
Tina90en.part09.rar (4.39 MB , 下载次数: 484 )
Tina90en.part10.rar (4.39 MB , 下载次数: 586 )
Tina90en.part11.rar (4.39 MB , 下载次数: 462 )
Tina90en.part12.rar (4.39 MB , 下载次数: 474 )
Tina90en.part13.rar (1.34 MB , 下载次数: 501 )
发表于 2010-5-1 21:31:25 | 显示全部楼层
thanks for sharing
发表于 2010-5-2 06:54:32 | 显示全部楼层
downloa1
发表于 2010-5-2 06:55:37 | 显示全部楼层
downloa2
发表于 2010-5-2 06:57:17 | 显示全部楼层
downloa3
发表于 2010-5-2 06:59:38 | 显示全部楼层
downloa4
发表于 2010-5-2 07:01:06 | 显示全部楼层
downloa5
发表于 2010-5-2 07:02:12 | 显示全部楼层
downloa6
发表于 2010-5-2 10:27:18 | 显示全部楼层
downloa7
发表于 2010-5-2 10:29:12 | 显示全部楼层
downloa8
GMT+8, 2025-10-30 06:59 , Processed in 0.030094 second(s), 6 queries , Gzip On, Redis On.
