查看: 13607|回复: 68
[原创] CADENCE Orcad 16.3
发表于 2010-4-27 02:09:01 | 显示全部楼层 |阅读模式
Cadence SPB / OrCAD 16.30.000 is a comprehensive package of design of electronic circuits, analog and digital simulation, IC design of programmable logic and custom circuits, as well as the development and preparation for the production of printed circuit boards.
This release combines previously unreleased separate products from Cadence - Allegro SPB and OrCAD. When you install you must install one of the Cadence SPB 16.3 ticks or Cadence OrCAD 16.3. Package OrCAD is a subset of SPB. So if you want to set the maximum option - select the SPB and do not choose OrCAD. Choice of two options will not add additional programs or Fitch.
 楼主| 发表于 2010-4-27 02:10:23 | 显示全部楼层
Installing Cadence SPB / Orcad 16.3
1. Install the license server
2. Overwrite file cdslmd.exe in the installation folder of the license manager on the tablet attached to the
3. Run LicenseServerConfiguration.exe folder license manager (LicenseManager)
4. In the Select license, select the edited file license163.lic
5. Click Next
6. In the Port number edit check the value 5280
7. In the editing window Host Name check your machine's hostname (computer name)
8. Click Next
9. Click Next again
10. Click Finish
11. Reboot
12. Set Cadence SPB / OrCAD 16.3
13. Copy the files from a folder ... Aspirinpatch into the c:\cadence directory
14. Start RunMe!. Bat
15. Wait
16. Wait a little
 楼主| 发表于 2010-4-27 02:11:31 | 显示全部楼层
 楼主| 发表于 2010-4-27 02:14:27 | 显示全部楼层
Hotfix_SPB16.30.001_win.part1.rar (95.78 MB)   http://www.multiupload.com/QZQS0M0OL0
 楼主| 发表于 2010-4-27 02:15:39 | 显示全部楼层
Hotfix_SPB16.30.001_win.part2.rar (95.78 MB)   http://www.multiupload.com/X2L2MFSC1S
 楼主| 发表于 2010-4-27 02:17:43 | 显示全部楼层
Hotfix_SPB16.30.001_win.part3.rar (95.78 MB)   http://www.multiupload.com/TW7KZMRSIT
 楼主| 发表于 2010-4-27 02:18:56 | 显示全部楼层
Hotfix_SPB16.30.001_win.part4.rar (14.82 MB)   http://www.multiupload.com/NEP2U5GVAR
 楼主| 发表于 2010-4-27 02:20:05 | 显示全部楼层
 楼主| 发表于 2010-4-27 02:23:04 | 显示全部楼层
19. Enjoy the Cadence SPB / OrCAD 16.3
 楼主| 发表于 2010-4-27 02:24:10 | 显示全部楼层
System requirements:
Operating system: Windows 2008 Server, Windows 2003 Server, all Service Packs (only 32-bit); Windows XP Professional; Windows Vista (32 and 64 bit) except Home Basic.
Processor: Intel IA-32 compatible (including Intel P4 EMT and AMD OpteronTM); 1.2 GHz minimum, recommended 2.4 GHz or more.
Memory: At least 1 GB of physical RAM, 2 GB recommended
Virtual memory: at least twice the available physical memory.
Disk space: minimum of 10 GB, 50 GB recommended
Display: 1024x768 @ 64000 colors recommended 1280x1024 @ 32-bit color
GMT+8, 2025-9-13 04:55 , Processed in 0.020692 second(s), 6 queries , Gzip On, Redis On.
