查看: 6681|回复: 3
请大侠帮助,我的5141出现一下问题,该怎么办?
发表于 2010-4-22 15:25:59 | 显示全部楼层 |阅读模式
etenv: Command not found. license manager: can't initialize: Cannot find license file. The license files (or license server system network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contact your software provider for a license file. Filename: /usr/local/flexlm/licenses/license.dat License path: /usr/local/flexlm/licenses/license.dat: FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory" For further information, refer to the FLEXnet Licensing End User Guide, available at "www.macrovision.com". 15:44:02 (lmgrd) ----------------------------------------------- 15:44:02 (lmgrd) Please Note: 15:44:02 (lmgrd) 15:44:02 (lmgrd) This log is intended for debug purposes only. 15:44:02 (lmgrd) In order to capture accurate license 15:44:02 (lmgrd) usage data into an organized repository, 15:44:02 (lmgrd) please enable report logging. Use Macrovision's 15:44:02 (lmgrd) software license administration solution, 15:44:02 (lmgrd) FLEXnet Manager, to readily gain visibility 15:44:02 (lmgrd) into license usage data and to create 15:44:02 (lmgrd) insightful reports on critical information like 15:44:02 (lmgrd) license availability and usage. FLEXnet Manager 15:44:02 (lmgrd) can be fully automated to run these reports on 15:44:02 (lmgrd) schedule and can be used to track license 15:44:02 (lmgrd) servers and usage across a heterogeneous 15:44:02 (lmgrd) network of servers including Windows NT, Linux 15:44:02 (lmgrd) and UNIX. Contact Macrovision at 15:44:02 (lmgrd) www.macrovision.com for more details on how to 15:44:02 (lmgrd) obtain an evaluation copy of FLEXnet Manager 15:44:02 (lmgrd) for your enterprise. 15:44:02 (lmgrd) 15:44:02 (lmgrd) ----------------------------------------------- 15:44:02 (lmgrd) 15:44:02 (lmgrd) 15:44:02 (lmgrd) Using license file "/usr/local/flexlm/licenses/license.dat" [singhi@singhi ~]$ icfb /home/singhi/eda/tools.lnx86/dfII/bin/icfb: line 17: cds_root: command not found Unable to find the Cadence software in your $PATH. Please fix this and try again. [singhi@singhi ~]$
 楼主| 发表于 2010-4-22 15:27:19 | 显示全部楼层
15:44:02 (lmgrd)
15:44:02 (lmgrd)
15:44:02 (lmgrd)
15:44:02 (lmgrd)
[singhi@singhi ~]$
发表于 2010-4-22 15:33:26 | 显示全部楼层
5141已破解 勿用lmgrd命令~     设置好bashrc或cshrc即可
发表于 2012-12-15 22:56:19 | 显示全部楼层
我也遇到一样的问题,如何解决呢?
GMT+8, 2025-12-29 07:59 , Processed in 0.023081 second(s), 6 queries , Gzip On, Redis On.
