查看: 57896|回复: 250
[原创] 【经典论坛首发】 A Practical Handbook On High Speed PCB and System Design
发表于 2010-3-29 14:51:22 | 显示全部楼层 |阅读模式
Right the First Time: A Practical Handbook On High Speed PCB and System Design
下载地址:
http://www.langfly.com/recommend/Recommend.do_uid-88618.jhtm
http://bbs.baishutang.cn/thread-1301-1-2.html
RightTheFirstTime-Final.part5.rar (2.27 MB , 下载次数: 976 )
Chapters 1-48
Chapter 1: Introduction
Chapter 2: The Electrical Engineering Problem
Chapter 3: Major Elements in an Electronic System
Chapter 4: Assumptions Often Made About Electronic Systems
Chapter 5: How Real Systems and Their Components Are Far From Ideal
Chapter 6: Transmission Lines
Chapter 7: What’s Moving on a Transmission Line?
Chapter 8: Basics of Electromagnetic Fields
Chapter 9: Digital vs. Rf/Microwave vs. Analog
Chapter 10: Time and Distance
Chapter 11: Inductance
Chapter 12: Capacitance
Chapter 13: Resistance
Chapter 14: Fundamentals of Transmission Lines
Chapter 15: The Concept of Ground and Power Planes
Chapter 16: Impedance
Chapter 17: Reflections – What Causes Them and What They Do to a Signal
Chapter 18: What is Meant by Signal Integrity Engineering
Chapter 19: When is a Design High-Speed?
Chapter 20: Controlling Reflections By Using Terminations
Chapter 21: Terminator Type, Terminator Placement and Net Sequencing
Chapter 22: Stubs on Transmission Lines?
Chapter 23: Properties of Transmission Lines That Affect Impedance
Chapter 24: Methods For Calculating and Measuring Impedance
Chapter 25: Right-Angle Bends and Vias: Potential Sources of Reflections and Other Problems
Chapter 26: Types of Drivers or Sources
Chapter 27: Types of Loads
Chapter 28: Bus Protocols
Chapter 29: Crosstalk or Coupling?
Chapter 30: Single-Ended Signaling
Chapter 31: Differential Signaling
Chapter 32: The Power Subsystem
Chapter 33: Power Distribution DC Drop
Chapter 34: Decoupling Capacitors
Chapter 35: Power Subsystem Inductance
Chapter 36: Power Dissipation Estimate
Chapter 37: Example Power Subsystem Design
Chapter 38: IC Packages – Vcc and Ground Bounce or SSN
Chapter 39: Noise Margins
Chapter 40: Design Rule Creation Using Noise Margin Analysis
Chapter 41: The PCB Fabrication Process
Chapter 42: PCB Materials
Chapter 43: Creating PCB Stackups
Chapter 44: Types of Vias
Chapter 45: PCB Design Process
Chapter 46: PCB Routing
Chapter 47: Documentation
Chapter 48: The Ideal Component Data Sheet
by Lee W. Ritchey (Author), John Zasio (Author), KELLA J. KNACK (Editor)
Publisher: Speeding Edge (June 2003)
Language: English
ISBN-10: 0974193607
ISBN-13: 978-0974193601
"Right the First Time, A Practical Handbook on High Speed PCB and System Design, Volume 1," is the premier publication of Speeding Edge. It was written by Speeding Edge founder and president, Lee W. Ritchey, co-authored by John Zasio, an recognized industry expert in high-speed design, and edited by Kella J. Knack, former editor of Printed Circuit Design and ASIC&EDA magazines. Published in the summer of 2003, the book is a thorough, comprehensive technical publication that addresses all aspects of high-speed PCB and system design and also includes several chapters on power subsystem design.
The book describes all of the principles involved in high-speed design such as transmission line management, signal integrity, power subsystem design, PCB materials and EMI control. Each technical term is defined in terms of its physics and how it applies to high-speed design. In addition, PCB material and fabricator selection, cost issues and design trade-off decisions are discussed in detail to provide the complete picture of all the factors involved in designing and implementing high-speed systems.
While geared towards engineering professionals, the book is also of significant value to anyone involved in making business decisions relative to designing and implementing high-speed systems. It presents a complete picture of what goes into developing a high-speed system including PCB material and fabricator selection; cost issues and design trade-off decisions. It also contains an exhaustive glossary of technical terms, their definitions and their use relative to high-speed design.  Click here for an Errata Sheet.
RightTheFirstTime-Final.part1.rar
4.88 MB, 下载次数: 1642 , 下载积分: 资产 -3 信元, 下载支出 3 信元
RightTheFirstTime-Final.part2.rar
4.88 MB, 下载次数: 1375 , 下载积分: 资产 -3 信元, 下载支出 3 信元
RightTheFirstTime-Final.part3.rar
4.88 MB, 下载次数: 2157 , 下载积分: 资产 -3 信元, 下载支出 3 信元
RightTheFirstTime-Final.part4.rar
4.88 MB, 下载次数: 1273 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2010-3-29 14:57:16 | 显示全部楼层
dsfadsfasdfasdf
 楼主| 发表于 2010-3-29 15:07:27 | 显示全部楼层
dingqi lai
发表于 2010-3-29 15:20:26 | 显示全部楼层
zanzanzan!
发表于 2010-3-29 15:22:07 | 显示全部楼层
Thank you for sharing!
 楼主| 发表于 2010-3-29 15:57:50 | 显示全部楼层
发表于 2010-3-29 17:13:15 | 显示全部楼层
good, thanks.
发表于 2010-3-29 17:23:49 | 显示全部楼层
good!!!
发表于 2010-3-29 17:34:44 | 显示全部楼层
3q very much
发表于 2010-3-29 19:24:18 | 显示全部楼层
kankan
GMT+8, 2025-9-15 04:57 , Processed in 0.020730 second(s), 9 queries , Gzip On, Redis On.
