查看: 3785|回复: 5
[招聘] AMD大量内部推荐职位3月25日更新!
发表于 2010-3-13 10:19:59 | 显示全部楼层 |阅读模式
内部推荐AMD上海研发中心诸多急招职位,有兴趣有实力者可联系我fusionlux@gmail.com,合适的话我帮你内部推荐,大家一起Win With AMD。
JOB TITLE:
MTS Physical Design Engineer
DESCRIPTION OF DUTIES IN ADDITION TO THOSE IN JOB DESCRIPTION:
Work with global Front-End design team and physical design team for large scale ASIC
chip physical implementation. Focus on physical design of deep sub-micron GPU chips
including block level (full chip) floor planning, timing closure, place&route, physical
verification etc.
PREFERRED EXPERIENCE:
1. PhD with 3+ years of industrial experience or MSEE with 5+ years of industrial
experience in ASIC design
2. Experience on hierarchical design from chip level to block level.
3. Expertise in place and routing, signal integrity, power analysis, CTS design, DFT,
design rule and connectivity verification, timing closure.
4. Successfully gone through complete product development cycle. Good analytical and
debugging skills
5. Good listening, writing and speaking English.
6. Good communication skills, strong interpersonal skills and the flexibility. Dedicated,
hard working and good team player
7. Familiar with Back-End (physical design) EDA tools (synopsys, cadence, magma)
8. Familiar with Front-End EDA tools or circuit design is a plus
9. Familiar with Unix/Linux environment and good at scripts
JOB TITLE:
MTS ASIC Design Engineer
1. Responsible for Front-End chip implementation including design, implementation
and execution of the flow that starts with RTL code and ends with the delivery of a
netlist package ready for physical design
2. Build test bench and monitors for DUT
3. Debug function/performance bugs of relative memory control blocks
1. MS or above of EE or related fields.
2. A solid foundation of Computer Architecture or DDR feature or memory controller
3. At least 5 years work experience on Design.
4. Proficient on Verilog and asic design flow
5. Familiar with Perl or other script language
6. Fluency in English
7. Good at communication
Job Title:
Staff/ Sr. GPU ASIC Integration Engineer
- Responsible for the execution of the chip integration process. This will include
design, implementation and execution of the flow that starts with RTL code and ends
with the delivery of a netlist package ready for physical design.
- Responsible for synthesis, netlist generation, timing and logical equivalency checks,
and timing constraint management. In this role you will get to experience many
aspects of the chip design process working as the bridge between the logic design &
verification group and the physical design group. Every piece of the design that will
make it into the final chip will at some point pass through your virtual hands.
1. Master Degree in electrical engineering with 4+ years of digital circuit design and
logic design experience; Or Bachelor Degree with 7+ years related working
experience
2. Familiar with Verilog HDL coding and ASIC Frond-End flow
3. Familiar with unix/linux and scripts (tcl, perl etc.)
4. Strong task-based organization skill
5. Computer Architecture and computer Arithmatic
6. Computer Graphic Basic knowledge(a plus)
7. DDR-SDRAM/PCI/PCI-e experience(a plus)
Job Title:
Staff ASIC Verification Engineer___Display
- Responsible for display IP development and maintenance
- Responsible for IP level synthesis/formal check
- Work with verification engineer on IP level validation
- Work with front-end integration team and physical design team on timing closure
- Communication with driver team to build driver
- Bachelor with 5+ yeas and Master with 3+ in Electrical or Computer Engineering.
- Strong RTL coding and familiar with front-end design flow
- Experience on synthesis, timing analysis and formal verification.
- Experience of Video/Graphics post-processor(scaling/composition/gamma/deinterlace)
is a plus
- Experience of display specific-interconnection protocols (DisplayPort, LVDS,
VGA,HDCP, DVI, HDMI etc) is a plus.
- Good at C/C++, Perl, familiar with SystemC, PLI, Makefile is a plus
- Design for verification (assertion based design strategies, code coverage, functional
coverage, test plan etc.)
- Good communication skills and fluent English.
- Strong responsibilities and team spirit.
Job Title:
Staff ASIC/Layout Design Engineer__PCIe
- Participate IP and SoC level architecture definition, derive functional and design
specifications and analyze feasibility of technical and architectures.
- Implement design with Verilog to achieve specification goals. Simulate and debug
the codes in coding stage.
- Go through the FE design flow to deliver qualified netlist. Feedback to Physical
Design team to help to close timing and check floorplan.
- Write ASIC specific part of test plan. Co-work with verification engineers to prove
functional correctness from block level to SoC level
- Support FW/SW bring-up and debugging
- Working as the technical point of contact on the ASIC area.
- Maintain design environment, solve flow issues, and develop scripts to improve flow
efficiency.
- Major in EE & CS
- Proven ASIC / SoC Design Experience (5+ years as a bachelor, 3+ years as a master).
- Must have strong background on IP development
- Must be proficient in Verilog coding, debugging and modeling
- Must be skilled in ASIC design flow, such as synthesis, DFT, timing analysis, ECO
etc.
- Must be skilled in mainstream EDA tools for design and simulation such as
ncsim/vcs, RC/DC, PT, Formality/LEC and DFT.
- Must be familiar with verification methodologies for from block level to SoC level.
- Should be familiar with shell/perl/tcl programming in linux OS.
- Should be familiar with P&R and Manufacture tech.
- Good English hearing, speaking, reading and writing capabilities.
- Will be a big plus if having mass production tapeout experience.
- Will be a plus if having C/C++/SystemVerilog experience
Job Title:
Staff ASIC/Layout Design Engineer__South Bridge
DESCRIPTION OF DUTIES IN ADDITION TO THOSE IN JOB DESCRIPTION :
The AMD South Bridges Group has openings for a MTS/Sr. Design Verification
Engineer. The successful candidate will apply current functional verification techniques
to perform and improve pre-silicon verification quality and product Time to Market for
Southbridge design. He/She should be able to work independently on various DV tasks
and providing technical guidences to the DV team. The candidate would involve
technically in the porting/creation of the DV environment for the new design, block and
chip level testplan creation and implementation, coverage analysis, and regression
cleanup.
- MSEE,BSEE or equivalent degree,
- Minimum of 3 years of ASIC design verification experience.
- Knowledge of design verification methodologies.
- Some of the peripheral I/O interfaces, such as PCIE, USB, SATA,PCI, SD, JTAG or
Ethernet.
- Shell/perl/Makefile programming in linux OS.
- Verilog design/simulation and SystemC/C++ programming
- Hardware assertion languages such as PSL/SVA,
- Test bench creation and functional coverage with HDL's such as System Verilog or
SystemC.
Good verbal and written communication skills in both Chinese and English.
Job Title:
Sr. DV Engineer
We are currently looking for an Senior Eng Design Verification Engineer who will be
responsible for all aspects of verification on next generation integrated processors chipset,
including developing DV infrastructure environment, testbenches, modeling,
assertions/checkers/monitors, test plan & test development, regressions, and
infrastructure development. Responsibility includes participating in the pre-silicon blocks,
chip, multi-chip and system level verification strategy:
- Verification of Graphic North Bridge design using complex DV environment C/C++,
SystemVeilog, OVM, SystemC, Verilog - Infrastructure development
- Experience in use of front end CAD tools Synopsys (VCS, )
- Strong documentation and communication skills.
- Ability to work well in a dynamic, fast-paced, pressure filled, multiple sites North
America and Asia
- Flexible in terms of responsibilities and hours.
- Bachelor/Master in Electrical/Computer Engineering.
- Strong C and C++ software development and scripting languages (Perl, C Shell,
Makefile, …) experience.
- Good knowledge of SystemVerilog and OVM is desirable.
- 3+ years experience in Verification in a large scale ASIC design environment.
- Strong background with hardware verification methodologies such as coverage-based
verification methodology with the use of hardware assertions (PSL or SVA).
- Strong analytical thinking skills, excellent attention to detail, and good coding skills
are required.
- Must be organized, enthusiastic self-starter and have good communication skills and
the ability and desire to work as a team.
Job Title:
MTS. SOC ASIC CAD engineer
- Participate in the design and implementation of the leading edge, front-to-back ASIC
design flow which covers logical and physical implementation and analysis of
complex devices that integrate multiple cores and IP’s from organizations with AMD
global teams.
- Participate in the research of Design Methodology to improve automation and
productivity to produce AMD's new high-quality cutting-edge graphics processing
products
- Technical support and programming
- Interface with EDA venders on technology
- major in EE, CS or related, Master Degree with 5+ years or Bachelor with 7+ years
working experiences
- good programming skill with one or more languages (eg, tcl, perl , python, c/c++, etc)
in unix/linux and a strong desire to automate flow
- experience in ASIC design (digital design, Front-end or Back-end,)
- familiar with one or more ASIC flows (logic synthesis, STA, formality check, Design
for Power ) and usage of related EDA tools
- Good written and spoken English
- Good communication skills and be able to work both independently and in a team
Job Title:
Sr. SOC ASIC CAD engineer
global teams.
products
- major in EE, CS or related, Master Degree with 3+ years or Bachelor with 5+ years
working experiences
Job Title:
Front-end ASIC Design CAD Engineer for Graphics Hardware
- Understand the FE ASIC design flow, design verification flow, and integration flow.
- Consolidate the design and verification methodologies for graphics and microprocessor
hardware.
- Develop infrastructure and release for variant IP/SOC teams.
- Explore the advanced design and verification methodologies for high efficient R&D.
- Good written and fluent oral English
- Graduates from Electrical Engineering (EE) or Computer Science (CS)
- Master with 2+ working experience, or Bachelor with 3+ working experience
- Familiar with Linux Environment (including shell scripting and linux gnu tools)
- Scripting language experience a plus (perl, ruby, tcl, etc.)
- Experience with design verification methodologies (plus)
- Major in EE required:
2+ year experience on Verilog HDL coding and debugging
1+ year experience on c/c++
Familiar with SystemVerilog
- Major in CS required:
3+ year experience on c/c++
1+ year experience on Verilog HDL coding and debugging (plus)
Familiar with SystemVerilog or SystemC (plus)
JOB TITLE:
MTS Design Engineer__Southbridge
Shanghai
The AMD South Bridges Group has an opening for MTS Design Engineer familiar with
USB technology. The successful candidate will work with team members and apply
his/her design techniques to work on different phases of complex logic design for USB
host controllers in Southbridge. The role will include working on the following tasks
from time to time, specification, HDL coding, synthesis, timing closure, etc. The job may
require some lab bringup and debugging of our reference PC system after the
Southbridge chip comes back.
1. The successful candidate will have a MSEE,BSEE or equivalent degree.
2. Must have minimum of 5+ years of ASIC design experience, proficient in
RTL(verilog), experienced with top level integration tasks, familiar with simulation,
synthesis, and timing.
3. The candidate must have the experience/knowledge of USB 1.1/2.0 and
OHCI/EHCI.
4. It is preferred the candidate is familiar with USB 3.0 and xHCI.
5. The candidate must exhibit good verbal and written communication skills in both
6. Hands-on lab experience is a plus, able to understand and/or use the use scopes,
logic analyzers, has knowledge or skill of PC system lab debugging.
JOB TITLE:
Sr. Eng DV Engineer__Fusion
We are currently looking for Senior Eng Design Verification Engineers who will be
responsible for all aspects of verification on next generation integrated processors (CPU
+ GPU + Multi Media) chipset, including developing testbenches, modeling,
- Verification of Graphic North Bridge design using random methodologies – Test
Planning, Implementation and Execution.
- Develop System Verilog (OVM) random sequences and methods.
- Maintain and Interface with existing random generators, models and APIs
- Integration of random modules to various testbenches.
- Executing verification through directed and random tests for its functionality and
interface protocols and tracking bug reports. Creation of the needed test libraries, test
API, simulation models. Debugging regression failures and identify the cause.
- Ability to work well in a dynamic, fast-paced, pressure filled, across multiple sites
North America and Asia
- 4+ years experience in complex ASIC/SOC Design Verification, direct experience in
SOC or Processor (GPU or CPU) or Industry bus standard (PCI-e, MC, HT) or
multimedia/video is preferred.
- Good knowledge of SystemVerilog and OVM.
- Good knowledge of Verilog/C/C++/System C/SystemVerilog.
- 2+ years experience in Verification.
- Verification insights into random techniques.
- Verification of large scale ASICs.
- Working knowledge of x86 assembly programming is an asset.
- Experience in power verification is an asset.
- Verification of Virtualization Components is an asset.
are required.
JOB TITLE:
Senior Program Manager – GPU Solutions Engineering
The individual who fills this role will be responsible for driving programs from inception
to full deployment. This individual will lead cross-functional product development core
teams, aligning all aspects of engineering and operation execution to meet business goals.
This individual will interact with AMD executives and senior management team, 3rdparty
partners, and possibly customers. This individual will be responsible for the
management of program execution and its day-to-day activities centered around GPU
development, post-silicon validation, and pre-production ramp. This individual will work
with engineering management to drive execution excellence, including key metrics like
Time-to-Market, Time-to-Yield, and Silicon Quality Indicators. This individual will work
collaboratively with the AMD Program Management community on infrastructure
development and continuous process improvement. Work is strategic and tactical in
nature with execution excellence being a key priority. Communication is a critical part of
this role which includes interpreting/understanding business directions, explaining
tactical details, and recommending solutions regarding complex program situations. The
job may lead to more supervisory roles, and working directly with executives. Travel is
expected for this role.
- BS in EE (or equivalent). Masters in EE or Engineering/Operations Management (or
equivalent) preferred.
- Experience in managing large, complex, interrelated projects, programs, and
functions to aggressive deadlines.
- Experience in large scale ASIC development, including definition, integration,
physical design, and design verification.
- Working knowledge across multiple engineering disciplines (i.e. Boards, Thermal,
Packaging, Process Technology, Product Engineering, Software) is desirable.
- Experience in Operations, Product Marketing, and/or Product Management is a plus.
- Ten years minimum related experience with five years (plus) management experience
- Experience with programs that can change quickly and may be speculative in nature.
- Results driven, disciplined, and analytical.
- Good problem solving skills, interpersonal skills, communications skills, and
teamwork spirit.
 楼主| 发表于 2010-3-16 08:19:12 | 显示全部楼层
欢迎大家继续关注。MTS和SMTS都是很高的技术职位了,相当于一般走管理路线的leader 和 Manager。
所以非常欢迎牛人加盟!由于我来信必回,可能会在我这一关把不符合要求的朋友直接拒掉,这里先说对不起了!至于递上去了的,如果您长时间没收到消息,可以再询问我,我会帮您打听。尽量让大家不由于我的缘故做无谓的等待。
 楼主| 发表于 2010-3-26 00:44:48 | 显示全部楼层
最近公司又放出了大量职位,主贴我已经更新,有不少Sr.职位,欢迎精英加盟。
发表于 2010-6-15 19:52:47 | 显示全部楼层
gooddaa
发表于 2010-7-30 18:23:00 | 显示全部楼层
发表于 2011-4-1 15:31:48 | 显示全部楼层
楼主 你好 想问下 有测试的职位招聘吗?
GMT+8, 2025-12-21 03:56 , Processed in 0.029050 second(s), 8 queries , Gzip On, Redis On.
