查看: 3203|回复: 8
Problem with ISE_TCAD_WINDOWS version..
发表于 2010-3-12 00:16:11 | 显示全部楼层 |阅读模式
Dear frnds,
ISE_TCAD_WINDOWS version 10.0 sp2's mdraw is not running with cygwin....please see the pic file...it says...dialogs.uid could not be opened. what would be the reason? i thought it needs Mrm files..actually motif.tar file...but cygwin support lesstif file....i installed but it did not run..yet. i also installed exceed for other like dios...please help.
发表于 2010-7-28 11:02:23 | 显示全部楼层
帮你顶了
发表于 2010-8-2 04:02:44 | 显示全部楼层
在10.0以後版本,mdraw 被device取代了。
发表于 2010-8-2 11:56:18 | 显示全部楼层
我记得没有windows版本把,是不是你没有设置语言US=LONG
发表于 2010-8-4 23:15:12 | 显示全部楼层
good information!!!!
发表于 2010-8-7 22:48:46 | 显示全部楼层
谢过楼主!
发表于 2010-8-17 16:27:45 | 显示全部楼层
帮你顶一下 等待高人
发表于 2010-10-30 10:05:01 | 显示全部楼层
谢谢,
发表于 2017-8-10 20:32:45 | 显示全部楼层
回复 1# gman
    看起来不容易解决
GMT+8, 2025-12-30 07:26 , Processed in 0.021808 second(s), 8 queries , Gzip On, Redis On.
