查看: 6305|回复: 18
Faraday FA526CPU
发表于 2006-8-27 07:49:14 | 显示全部楼层 |阅读模式
The FA526 is a general-purpose 32-bit embedded RISC processor, including a synthesized CPU core, an MMU, separate caches, scratchpads, and other units. The CPU core implements the ARM V4® architecture. Configurable features are available for the caches, scratchpads, and write buffer. The FA526 provides operation frequencies up to 200 MHz (worst case) with low operation power. It is suitable for a wide range of applications, especially those needing to achieve high performance with low cost and low power consumption. The single-phase clock and standard-cell based approach employed make it easy to integrate the FA526 in an SoC design. Detailed features of the FA526 are described in the following feature list.
FA526_PB_v1.1.pdf
57.59 KB, 下载次数: 31 , 下载积分: 资产 -2 信元, 下载支出 2 信元
FA526
发表于 2006-9-15 12:33:39 | 显示全部楼层
[广告]: 亿涛工作室
[下载]Building a RISC System in an FPGA, by Jan Gray
太小气了吧
斑竹
发表于 2006-9-21 16:28:29 | 显示全部楼层
好东西啊~~~
发表于 2006-9-23 22:43:07 | 显示全部楼层
asdgasdg
asgasgsadg
发表于 2006-9-23 22:43:26 | 显示全部楼层
asdgsadgsadg
asdgasgsag
发表于 2006-9-23 22:43:39 | 显示全部楼层
asdgasdgasdg
asdgsagag
发表于 2010-6-18 21:36:04 | 显示全部楼层
great
thanks
发表于 2010-7-16 20:15:57 | 显示全部楼层
thanks a lot!!!!!!!!!!
发表于 2010-7-16 20:47:19 | 显示全部楼层
支持~~~~~~~~~
发表于 2010-7-16 20:50:23 | 显示全部楼层
支持~~~~~~~~~
GMT+8, 2025-12-26 07:32 , Processed in 0.131722 second(s), 8 queries , Gzip On, Redis On.
