查看: 6140|回复: 4
[求助] 问个PLL RMS phase error的问题
发表于 2010-3-3 14:17:55 | 显示全部楼层 |阅读模式
在计算PLL RMS phase error时,积分的上下限怎么定?跟环路带宽的关系怎样?谢谢
发表于 2010-3-4 12:00:56 | 显示全部楼层
基本上是从低频处开始 到信号带宽,比如从1kHz 到4MHz 跟所处理的信号带宽由关系。
发表于 2010-3-7 21:31:40 | 显示全部楼层
我来引用一下我在书上看到的一种说法:" the lower limit is set by the bandwidth of a frequency error correction algorithm, which is typically adopted in the digital base band subsystem. The upper frequency is set approximately by the signal bandwidth. In practice, a phase noise at frequency offsets larger than the channel bandwidth has a negligible impact on detection loss"
 楼主| 发表于 2010-3-8 20:18:55 | 显示全部楼层
我来引用一下我在书上看到的一种说法:" the lower limit is set by the bandwidth of a frequency error correction algorithm, which is typically adopted in the digital base band subsystem. The upper freque ...
depend135 发表于 2010-3-7 21:31
请问下是哪本书?谢谢
发表于 2014-3-10 10:12:40 | 显示全部楼层
请问能帮忙分享一些关于RMS结构的资料不,604483778@qq.com
麻烦了。
GMT+8, 2025-12-28 22:24 , Processed in 0.021107 second(s), 6 queries , Gzip On, Redis On.
