查看: 13827|回复: 57
[资料] Advanced_Formal_Verification_eBook
发表于 2010-2-21 15:57:02 | 显示全部楼层 |阅读模式
Edited by
Rolf Drechsler
Contents
Preface        xi
Contributing Authors                                                    xiii
Introduction                                                            xix
Rolf Drechsler
    1     Formal Verification                                            xix
    2     Challenges                                                    xxi
    3     Contributions to this Book                                   xxiii
1
        1
What Sat-Solvers can and cannot do
Eugene Goldberg
    1     Introduction                                                    1
    2     Hard Equivalence Checking CNF formulas                          3
        3
          2.1    Introduction
          2.2    Common Specification of Boolean Circuits                  5
          2.3    Equivalence Checking as SAT                             11
                 Class M (p) and general resolution                      12
          2.4
          2.5    Computation of existentially implied functions          13
          2.6    Equivalence Checking in General Resolution              14
          2.7    Equivalence Checking of Circuits with Unknown CS        20
          2.8    A Procedure of Equivalence Checking for Circuits with
                 a Known CS                                              22
          2.9    Experimental Results                                    23
          2.10 Conclusions                                               26
    3     Stable Sets of Points                                          26
          3.1    Introduction                                            26
          3.2    Stable Set of Points                                    28
          3.3    SSP as a reachable set of points                        31
          3.4    Testing Satisfiability of CNF Formulas by SSP Con-
        32
                 struction
          3.5    Testing Satisfiability of Symmetric CNF Formulas by
                 SSP Construction                                        35
        39
          3.6    SSPs with Excluded Directions
          3.7    Conclusions                                             42
                                      v
vi                                 ADVANCED FORMAL VERIFICATION
2
        45
Advancements in mixed BDD and SAT techniques
Gianpiero Cabodi and Stefano Quer
   1      Introduction                                                45
   2      Background                                                  47
          2.1    SAT Solvers                                          47
          2.2    Binary Decision Diagrams                             48
          2.2.1 Zero-Suppressed Binary Decision Diagrams              49
          2.2.2 Boolean Expression Diagrams                           50
          2.3    Model Checking and Equivalence Checking              52
   3      Comparing SAT and BDD Approaches: Are they different?        54
          3.1    Theoretical Considerations                           54
          3.2    Experimental Benchmarking                            55
          3.2.1 Bug Hunting in an Industrial Setting                  56
          3.2.2 Modifying BDD-based Techniques to Perform BMC         56
          3.2.3 Conclusions                                           58
          3.3    Working on Affinities: Variable Order                  58
          3.3.1 Affinities on circuit-width correlation                 59
          3.3.2 Recursion tree and Variable Order                     59
          3.3.3 A Common Static Variable Order Heuristic              60
          3.3.4 Conclusions                                           60
   4      Decision Diagrams as a Slave Engine in general SAT: Clause
          Compression by Means of ZBDDs                               61
                 ZBDDs for Symbolic Davis-Putnam Resolution           61
          4.1
                 ZBDDs for Symbolic DLL                               62
          4.2
                 ZBDDs for Breadth-First SAT                          62
          4.3
                 Conclusions                                          62
          4.4
   5      Decision Diagram Preprocessing and Circuit-Based SAT        62
          5.1    BED Preprocessing                                    63
          5.2    Circuit-Based SAT                                    64
          5.2.1 BDD Sweeping and SAT                                  64
          5.2.2 SAT on BEDs                                           66
          5.3    Preprocessing by Approximate Reachability            67
   6      Using SAT in Symbolic Reachability Analysis                 68
          6.0.1 BDDs at SAT leaves                                    69
          6.0.2 SAT-Based Symbolic Image and Pre-image                70
   7      Conclusions, Remarks and Future Works                       71
3
        77
Equivalence Checking of Arithmetic Circuits
Dominik Stoffel, Evgeny Karibaev, Irina Kufareva and Wolfgang Kunz
   1      Introduction                                                78
   2      Verification Using Functional Properties                     81
   3      Bit-Level Decision Diagrams                                 85
   4      Word-Level Decision Diagrams                                88
          4.1    Pseudo-Boolean functions and decompositions          89
          4.2    *BMDs                                                92
          4.3    Equivalence Checking Using *BMDs                     94
          4.4    Experiments with *BMD synthesis                      97
   5      Arithmetic Bit-Level Verification                           105
          5.1    Verification at the Arithmetic Bit Level             108
          5.2    Extracting the Half Adder Network                   112
        vii
Contents
          5.3    Verification Framework                               115
          5.4    Experimental Results                                115
   6      Conclusion                                                 118
   7      Future Perspectives                                        119
4
        125
Application of Property Checking and Underlying Techniques
Raik Brinkmann, Peer Johannsen and Klaus Winkelmann
   1      Circuit Verification Environment: User’s View               126
          1.1    Tool Environment                                    126
          1.2    The gateprop Property Checker                       127
   2      Circuit Verification Environment: Underlying Techniques     129
          2.1    From Property to Satisfiability                      129
          2.2    Preserving Structure during Problem Construction    131
          2.3    The Experimental Platform RtProp                    132
   3      Exploiting Symmetries                                      133
          3.1    Symmetry in Property Checking Problems              133
          3.2    Finding Symmetrical Value Vectors                   136
          3.3    Practical Results                                   140
   4      Automated Data Path Scaling to Speed Up Property Checking  142
          4.1    Bitvector Satisfiability Problems                   143
          4.2    Formal Abstraction Techniques                       145
          4.3    Speeding Up Hardware Verification by One-To-One Ab-
                 straction                                           146
          4.4    Data Path Scaling of Circuit Designs                147
   5      Property Checking Use Cases                                152
          5.1    Application Example: Reverse Engineering            155
          5.1.1 Functionality                                        155
          5.1.2 Task                                                 155
          5.1.3 Examples for a property                              156
          5.1.4 Results                                              157
          5.2    Application Example: Complete Block-Level ASIC Ver-
                 ification                                            158
          5.2.1 Verification Challenge and Approach                   158
          5.2.2 Verifying the Control Path                           159
          5.2.3 Data Path Results                                    160
          5.2.4 Overall Result                                       160
          5.3    Productivity Statistics                             161
   6      Summary                                                    162
          6.1    Achievements                                        162
          6.2    Challenges and Perspectives                         163
5
        167
Assertion-Based Verification
Claudionor Nunes Coelho Jr. and Harry D. Foster
   1      Introduction                                               167
          1.1    Specifying properties                               169
          1.2    Observability and controllability                   171
          1.3    Formal property checking framework                  172
   2      Assertion Specification                                     177
          2.1    Temporal logic                                      177
          2.2    Property Specification Language (PSL)                179
viii                                ADVANCED FORMAL VERIFICATION
         2.2.1 Boolean layer                                         180
         2.2.2 Temporal layer                                        180
         2.2.3 Verification layer                                     182
     3   Assertion libraries                                         183
     4   Assertion simulation                                        184
     5   Assertions and formal verification                           186
         5.1     Handling complexity                                 186
         5.2     Formal property checking role                       190
     6   Assertions and synthesis                                    191
         6.1     On-line validation                                  191
         6.2     Synthesizable assertions                            192
         6.3     Routing scheme for assertion libraries              194
         6.4     Assertion processors                                195
         6.5     Impact of Assertions in Real Circuits               197
     7   PCI property specification example                           197
         7.1     PCI overview                                        198
         7.2     PCI master reset requirement                        199
         7.3     PCI burst order encoding requirement                199
         7.4     PCI basic read transaction                          200
     8   Summary                                                     202
6
        205
Formal Verification for Nonlinear Analog Systems
Walter Hartong, Ralf Klausen and Lars Hedrich
     1   Introduction                                                206
     2   System Description                                          206
         2.1     Analog Circuit Classes                              208
         2.2     State Space Description                             208
         2.2.1 Index                                                 209
         2.2.2 Solving a DAE System                                  209
         2.2.3 Linearized System Description                         211
     3   Equivalence Checking                                        211
         3.1     Basic Concepts                                      212
         3.1.1 Nonlinear Mapping of State Space Descriptions         212
         3.2     Equivalence Checking Algorithm                      213
         3.2.1 Sampling the State Space                              213
         3.2.2 Consistent Sample Point                               215
         3.3     Linear Transformation Theory                        217
         3.3.1 System Transformation to a Kronecker Canonical
                  Form                                               217
         3.3.2 DAE System Transformation into the Virtual State Space219
         3.3.3 Error Calculation                                     222
         3.4     Experimental Results                                222
         3.4.1 Schmitt Trigger Example                               222
         3.4.2 Bandpass Example                                      225
     4   Model Checking                                              227
         4.1     Model Checking Language                             227
         4.2     Analog Model Checking Algorithm                     230
         4.2.1 Transition Systems                                    230
         4.2.2 Discrete Time Steps                                   231
         4.2.3 State Space Subdivision                               232
         4.2.4 Transition Relation                                   234
                                                ix
Contents
         4.2.5 Border Problems                 236
         4.2.6 Input Value Model               237
         4.2.7 Optimizations                   239
         4.3   Experimental Results            239
         4.3.1 Schmitt Trigger Example         239
         4.3.2 Tunnel Diode Oscillator Example 240
   5     Summary                               242
   6     Acknowledgement                       242
   Appendix: Mathematical Symbols              243
Index
Advanced_Formal_Verification_eBook.pdf.rar
2.08 MB, 下载次数: 473 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-2-21 15:58:25 | 显示全部楼层
顶顶顶顶
 楼主| 发表于 2010-2-21 16:36:11 | 显示全部楼层
没人感兴趣吗
发表于 2010-2-22 10:32:25 | 显示全部楼层
thanks
发表于 2010-2-27 00:54:34 | 显示全部楼层
thanks!!!
发表于 2011-2-10 14:27:08 | 显示全部楼层
buo cuo ,duo xie
发表于 2011-3-22 23:28:14 | 显示全部楼层
解压成功,多谢分享
发表于 2012-2-9 14:53:52 | 显示全部楼层
不错,感谢分享~~
发表于 2012-6-21 16:25:29 | 显示全部楼层
不错的书,谢谢分享。
发表于 2012-6-21 16:26:56 | 显示全部楼层
good book, thanks.
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-10 16:42 , Processed in 0.109833 second(s), 4 queries , Gzip On, Redis On.
