查看: 4084|回复: 7
[资料] IEEE 论文-A Low-Voltage Low-Distortion MOS Sampling Switch
发表于 2010-2-21 15:09:39 | 显示全部楼层 |阅读模式
关于boostraped switch在低压下
In order to reduce distortion due to variation of the gate
overdrive and the threshold voltage, a novel low-voltage constantresistance
sampling switch is proposed in this paper. The technique
to reduce nonlinearity can be used in a high resolution sample and
hold circuit. TSMC 0.18um standard CMOS technology is utilized
in this research. Results indicate that much lower Total Harmonic
Distortion (THD) is achieved by the proposed circuit. The low
THD meets the requirements in the application of the low-voltage
low-distortion switched-capacitor circuits.
A Low-Voltage Low-Distortion MOS Sampling Switch.pdf
522.01 KB, 下载次数: 69 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-4-7 15:44:35 | 显示全部楼层
发表于 2011-4-7 17:57:43 | 显示全部楼层
剛好用的到 感謝!
发表于 2011-4-8 11:32:16 | 显示全部楼层
是不是真的这么厉害呀,看看再说!
发表于 2012-3-20 11:39:20 | 显示全部楼层
kan........
发表于 2014-3-18 11:03:29 | 显示全部楼层
谢谢分享
发表于 2014-9-10 13:46:40 | 显示全部楼层
回复 1# sofie
fdgsfdgsfg
发表于 2014-9-14 11:12:13 | 显示全部楼层
谢谢分享,好好学习下。
GMT+8, 2025-12-29 11:17 , Processed in 0.025773 second(s), 8 queries , Gzip On, Redis On.
