查看: 6636|回复: 15
求救!C@dence RFKit 到底如何使用
发表于 2010-2-4 10:54:04 | 显示全部楼层 |阅读模式
已經安裝完畢,後來看安裝目錄的README.TXT,
2. untar the contents of the installation:
   The RF Methodology Kit contains a workshop document, a userguide
   document and a representative design database. The kit is structured to
   operate within a defined directory structure which should be copied to
   a local workspace.
   Example script for setting up the kit:
       cd <kit_working_dir>
       cp <kit_install_dir>/kits/RFKIT/rfkit_db_v81_008.tgz .
       cp <kit_install_dir>/kits/RFKIT/rfkit_workshop_manual_v81_008.tgz .
       cp <kit_install_dir>/kits/RFKIT/rfkit_userguide_v81_008.tgz .
       tar zxvf rfkit_db_v81_008.tgz
       tar zxvf rfkit_workshop_manual_v81_008.tgz
       tar zxvf rfkit_userguide_v81_008.tgz
為什麼我沒有這些檔案,反而是一些加密的東西,我已經將RF_SIP_KIT 加入license
有誰成功安裝可以使用的大大發個聲吧 ......
Installation of the RF Methodology Kit assumes the use of InstallScape
for BOTH Installation and Configuration steps. The downloaded files
are encrypted and will require a license with the feature RF_SIP_KIT
(part number KIT1010) to be available from your license server. During
the installation process, the Configuration step will attempt to checkout
this license key and if it cannot, installation of the kit will fail.
发表于 2010-2-6 10:50:09 | 显示全部楼层
RF kit本身应该美元License吧
发表于 2010-2-6 11:06:52 | 显示全部楼层
thank you!!!!!!!!!!!!!!!!
 楼主| 发表于 2010-2-8 10:24:58 | 显示全部楼层
可以請問一下到底如何使用嗎?
 楼主| 发表于 2010-2-9 10:30:36 | 显示全部楼层
rfkit_db_v81_008.tgzaa.enc
rfkit_db_v81_008.tgzab.enc
rfkit_db_v81_008.tgzac.enc
rfkit_db_v81_008.tgzad.enc
rfkit_db_v81_008.tgzacq.enc
請問我的目錄下面是這些檔案,我要怎樣讓它變成
rfkit_db_v81_008.tgz ???????
 楼主| 发表于 2010-2-9 10:34:27 | 显示全部楼层
還是有人已經安裝好,願意分享上傳下列檔案
感激不盡.......
发表于 2010-2-17 20:20:59 | 显示全部楼层
goooooooood
 楼主| 发表于 2010-2-22 17:43:22 | 显示全部楼层
有人知道嗎?
 楼主| 发表于 2010-2-23 08:44:28 | 显示全部楼层
救人喔 !!!
发表于 2010-3-2 19:33:58 | 显示全部楼层
Thanks
GMT+8, 2025-12-25 09:06 , Processed in 0.028854 second(s), 7 queries , Gzip On, Redis On.
