We are the high tech IC design company based in Shenzhen with well-established international background. Currently we are looking for two critical technical staffs with the following requirements. Please contact analog.cn@gmail.com if you are qualified and are interested in those high tech positions. Thanks.
Mixed-signal IC Design Engineer
MSEE, Ph.D. preferred, minimum 2 years of analog/mixed signal IC design experience. The candidate must have strong analog and mixed-signal electronics background and a solid understanding of analog building blocks, such as on-chip oscillator, bandgap, comparator, programmable current DAC, charge pump etc.; silicon proven design is a plus. Experience in circuit implementation, layout, and debugging; familiar with CAD tools (Pspice, Hspice etc.); basic knowledge of the semiconductor process is a plus.
System Application Engineer
BS/MS in electrical engineering (or equivalent) and two years of relevant experience are typically required. The candidate is expected to have a strong technical background in digital design and a strong knowledge of system level debugging; experience with PCB and schematic design tools, verilog/VHDL, C and assembly language. Experience with PWM/timer, programmable state machine & serial communication interface design is a plus. Good oral/written communication skills to effectively engage in the different R&D areas and with customers; self-motivated with the ability to work under pressure.
[ 本帖最后由 as1000 于 2006-8-22 08:52 编辑 ] |
