查看: 19640|回复: 42
Help for installing ASSURA 317 OA with IC610
发表于 2010-1-26 16:42:45 | 显示全部楼层 |阅读模式
Hi Great heroes,
Has anybody installed successfully  ASSURA317 Oa version with IC610?
Please let me know the procedure of installation and license file settings.
发表于 2010-2-12 21:28:07 | 显示全部楼层
hello, where can I find  it for OA version, not cdb, thanks in advance
 楼主| 发表于 2010-2-12 22:16:01 | 显示全部楼层
Hi Jinglee,
The OA version of ASSURA is available here on EETOP.
And fortunately I have successfully installed it with IC610, and its working fine.
If you need help I can guide you in this process.
here is the download link
http://www.eetop.cn/bbs/thread-167602-1-53.html
If you need further help , I am available alwaz.
Thanks
Farzad
Learn,Share,Deliver,Grow.
发表于 2010-2-14 23:07:48 | 显示全部楼层
can help me install it
thank for advange
 楼主| 发表于 2010-2-15 02:58:30 | 显示全部楼层
HI vanduongbk ,
You need a same patch which is used for IUS_83 crack.
The sfk & patch_cadence ...
Download the assura from the above mentioned link.
Copy the patch files into the installation directory.
run the patch_cadence... this will take couple of seconds.
Thanks
Farzad
发表于 2010-2-27 00:13:04 | 显示全部楼层
hi , bondultimate
where i can download IUS_83 crack
发表于 2010-2-27 00:15:57 | 显示全部楼层
hi , bondultimate
 楼主| 发表于 2010-2-27 00:36:19 | 显示全部楼层
Hi Vanduongbk,
Here you go..
http://www.eetop.cn/bbs/thread-185516-1-11.html
Download the pack and copy the patch_cadence & sfk file into top level directory.
run the patch_cadence,and you are done.
Let me know if you face any issues...
Thanks
Farzad
发表于 2010-3-6 13:51:41 | 显示全部楼层
thank you bondultimate very much
you are best man
you have use calibre
you can guide me install it
because when i copy 2 files sfk &patch to top folder of it and run ./patch
error
please me ,thank you very much
 楼主| 发表于 2010-3-6 15:34:24 | 显示全部楼层
Hi Van,
The patch files only wor for cadence tools.Calibre is a tool distributed by Mentor Graphics.
For calibre installation you have to generate a license key and you must have a Mentor KG license generator.The whole process is somewhat cumbersome,but the sucess is 100%.
search calibre crack on EETOP and download calibre 2009 version only.I will write you the steps soon.let me know when you are going to complete download.
Thanks
Farzad
GMT+8, 2025-9-13 04:34 , Processed in 0.027457 second(s), 6 queries , Gzip On, Redis On.
