查看: 15088|回复: 37
三极管生产工艺的设计和仿真(silvaco)
发表于 2010-1-23 23:02:44 | 显示全部楼层 |阅读模式
BJT Application Examples .rar (1.66 KB , 下载次数: 243 ) 基于silvaco的三极管生产工艺的设计和仿真代码,非本人设计,分享一下
发表于 2010-1-24 09:31:14 | 显示全部楼层
R2009b_crack
发表于 2010-1-26 21:55:27 | 显示全部楼层
代码:go athena
#TITLE: Polysilicon Emitter Bipolar Example - Ssuprem4->Devedit->Spisces2
# If you do not have Devedit: Please comment these lines out....
line x loc=0.0         spacing=0.03
line x loc=0.2         spacing=0.02
line x loc=0.24        spacing=0.015
line x loc=0.3         spacing=0.015
line x loc=0.8         spacing=0.15
line y loc=0.0         spacing=0.01
line y loc=0.07        spacing=0.01
line y loc=0.1         spacing=0.01
line y loc=0.12        spacing=0.01
line y loc=0.3         spacing=0.02
line y loc=0.5         spacing=0.06
line y loc=1.0         spacing=0.35
init c.arsenic=2e16
implant   boron  energy=18 dose=2.5e13
diffuse time=60 temp=920
# deposit polysilicon
deposit poly thick=0.3 divisions=6 min.space=0.05
# Implant to dope polysilicon
implant arsenic dose=7.5e15 energy=50
# Pattern the poly
etch poly right p1.x=0.2
relax y.min=.2 x.min=0.2
method compress fermi
diffuse time=25   temp=920 dryo2
diffuse time=50   temp=900 nitrogen
implant boron dose=2.5e13 energy=18
# deposit spacer
deposit oxide thick=0.4 divisions=10  min.space=0.1
# etch the spacer back
etch oxide dry thick=0.5
implant boron dose=1e15 energy=30
diffuse time=60 temp=900   nitrogen
structure reflect left
# put down Al and etch to form contacts
deposit alum thick=0.05 div=2
etch alum start x=-0.16 y=-4
etch continue x=-0.16 y=0.2
etch continue x=-0.6 y=0.2
etch done  x=-0.6 y=-4
etch alum right p1.x=0.15
# Name the electrodes for use with Atlas.....1,2,3
electrode x=0.0    name=emitter
electrode x=-0.65  name=base
electrode backside name=collector
#  Save the final structure
structure outfile=bjtex01_0.str
# Completely remesh the structure without obtuse triangles in the semiconductor
# Use the Sensitivity & Minspacing parameters to adjust the mesh density....
# .. the smaller the Sensitivity, the denser the mesh...
go devedit
base.mesh height=0.25 width=0.25
bound.cond apply=false max.ratio=300
constr.mesh max.angle=90 max.ratio=300 max.height=1 max.width=1 \
        min.height=0.0001 min.width=0.0001
constr.mesh type=Semiconductor default
constr.mesh type=Insulator default max.angle=170
constr.mesh type=Metal default max.angle=180
# Define the minimum mesh spacing globally...
imp.refine min.spacing=0.025
# Select a list of solution (impurity) gradients to refine upon....
imp.refine imp="Arsenic" sensitivity=0.5
imp.refine imp="Boron" sensitivity=0.5
# now mesh the structure....
mesh
struct outfile=bjtex01_1.str
##################### Gummel Plot Test ###########################
# Electrode names used in this test: Base, Collector, Emitter
go atlas
# set material models etc.
material taun0=5e-6 taup0=5e-6
contact name=emitter n.poly surf.rec
models bipolar print
# initial solution
solve init
# change to two carriers
method newton autonr trap
solve prev
# set the collector bias
solve vcollector=2 local
# start ramping the base
solve vbase=0.1
# Ramp the base to 0.9 volts....
log outf=bjtex01_2.log master
solve vbase=0.2 vstep=0.05 vfinal=0.9 name=base ac freq=1e6 aname=base
# Now dump a structure file, for tonyplotting... but first decide what
# you want in it, on top of the default quantities......
output e.field flowlines jx.el jx.ho jy.el jy.ho
save outf=bjtex01_3.str
tonyplot  bjtex01_3.str -set bjtex01_1.set
# Now extract some design parameters...
extract name="peak collector current" max(curve(abs(v."base"),abs(i."collector")))
extract name="peak gain" max(i."collector"/ i."base")
extract name="max fT" max(g."collector""base"/(2*3.1415*c."base""base"))
# plot the results
tonyplot  bjtex01_2.log -set bjtex01_2.set
quit
发表于 2010-2-3 22:25:28 | 显示全部楼层
thanks,
发表于 2010-2-8 10:19:45 | 显示全部楼层
下载看看撒…………
发表于 2010-4-23 21:20:16 | 显示全部楼层
youyonga
发表于 2010-4-24 05:07:31 | 显示全部楼层
5# shancjb kankan
发表于 2010-5-10 23:52:57 | 显示全部楼层
先看看~
发表于 2010-5-12 15:46:53 | 显示全部楼层
谢谢分享~~~~~~
发表于 2010-5-21 14:19:19 | 显示全部楼层
thanks
GMT+8, 2025-12-29 06:48 , Processed in 0.032034 second(s), 6 queries , Gzip On, Redis On.
