查看: 8122|回复: 8
designinganalogchips.pdf
发表于 2006-8-21 14:03:41 | 显示全部楼层 |阅读模式
Table of Contents
Analog World
1 Devices 1-1
Semiconductors 1-1
The Diode 1-5
The Bipolar Transistor 1-6
The Integrated Circuit 1-13
Integrated NPN Transistors 1-14
The Case of the Lateral PNP Transistor 1-22
CMOS Transistors 1-23
The Substrate PNP Transistor 1-27
Diodes 1-27
Zener Diodes 1-28
Resistors 1-29
Capacitors 1-32
Other Processes 1-33
CMOS vs. Bipolar 1-34
2 Simulation 2-1
What You Can Simulate 2-2
DC Analysis 2-2
AC Analysis 2-3
Transient Analysis 2-4
The Big Question of Variations 2-6
Models 2-8
The Diode Model 2-8
The Bipolar Transistor Model 2-10
The Model for the Lateral PNP Transistor 2-13
MOS Transistor Models 2-14
Resistor Models 2-16
Models for Capacitors 2-17
Pads and Pins 2-17
Just How Accurate is a Model? 2-18
3 Current Mirrors 3-1
4 The Royal Differential Pair 4-1
5 Current Sources 5-1
Bipolar 5-1
CMOS 5-7
The Ideal Current Source 5-7
6 Time Out: Analog Measures 6-1
dB 6-1
RMS 6-2
Noise 6-4
Fourier Analysis, Distortion 6-6
Frequency Compensation 6-9
7 Bandgap References 7-1
Low-Voltage Bandgap References 7-11
designinganalogchips.part1.rar
1.77 MB, 下载次数: 29 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-8-21 14:13:06 | 显示全部楼层
这是一本不错的书,很容易读的!
发表于 2006-8-21 19:45:18 | 显示全部楼层
还有一半呢???
发表于 2009-4-3 18:55:04 | 显示全部楼层
eetop
发表于 2011-3-31 10:58:05 | 显示全部楼层
O(∩_∩)O谢谢
发表于 2011-5-4 15:39:05 | 显示全部楼层
good thx !!!!
发表于 2011-5-17 05:53:36 | 显示全部楼层
Thank you!
发表于 2012-1-11 10:31:52 | 显示全部楼层
回复 7# sigint
    不全,打不开
发表于 2012-10-10 23:07:59 | 显示全部楼层
楼主 下一半呢?
GMT+8, 2025-12-20 19:19 , Processed in 0.048225 second(s), 4 queries , Gzip On, Redis On.
