查看: 14831|回复: 21
用Redhat Enterprise 4安装Cadence后不能使用Vpwl
发表于 2010-1-17 21:47:26 | 显示全部楼层 |阅读模式
生成网表时,Vpwl和Vpulse等器件都不能正常生成,很是纳闷。我用的操作系统是Redhat Enterprise 4。在主窗口里面提示的命令是:
Command line:
    /home/lijun/cadence/tools.lnx86/spectre/bin/32bit/spectre -env  \
        artist5.1.0 +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre0_7728_1 -format psfbin -raw ../psf  \
        +lqtimeout 900 input.scs
spectre pid = 7905
Loading /home/lijun/cadence/tools.lnx86/cmi/lib/4.0/libinfineon_sh.so ...
Loading /home/lijun/cadence/tools.lnx86/cmi/lib/4.0/libnortel_sh.so ...
Loading /home/lijun/cadence/tools.lnx86/cmi/lib/4.0/libphilips_sh.so ...
Loading /home/lijun/cadence/tools.lnx86/cmi/lib/4.0/libsparam_sh.so ...
Loading /home/lijun/cadence/tools.lnx86/cmi/lib/4.0/libstmodels_sh.so ...
spectre (ver. 5.10.41.052404 -- 24 May 2004).
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
        Security, Inc.
Simulating `input.scs' on localhost at 5:00:57 AM, Sat Jan 17, 2009.
Warning from spectre during circuit read-in.
    "input.scs" 9: Illegal unit prefix `v' ignored.
Opening directory /home/lijun/Project/Tech_lib/CSMC/models/res_va.va.ahdlcmi/
        (770)
Compiling ahdlcmi module library.
Failed to compile ahdlcmi module library, see
        /home/lijun/Project/Tech_lib/CSMC/models/res_va.va.ahdlcmi/ for
        details
Could not open ahdlcmi module library
        /home/lijun/Project/Tech_lib/CSMC/models/res_va.va.ahdlcmi/obj/Linux2.6.9-78.EL+gcc/optimize/libahdlcmi.so
        /home/lijun/Project/Tech_lib/CSMC/models/res_va.va.ahdlcmi/obj/Linux2.6.9-78.EL+gcc/optimize/libahdlcmi.so:
        cannot open shared object file: No such file or directory
Warning from spectre in `LvComp_Wind_v01', during circuit read-in.
    NM6: `ad' is not a valid parameter for an instance of `mnbn'.  Ignored.
    NM6: `as' is not a valid parameter for an instance of `mnbn'.  Ignored.
    NM6: `pd' is not a valid parameter for an instance of `mnbn'.  Ignored.
    NM6: `ps' is not a valid parameter for an instance of `mnbn'.  Ignored.
        Further occurrences of this warning will be suppressed.
    NM3: `ad' is not a valid parameter for an instance of `mnbn'.  Ignored.
Warning from spectre during hierarchy flattening.
    defineQ: Unit of quantity `Q' is changed from `coul' to `C'.
    defineFreq: Unit of quantity `F' is changed from `N' to `Hz'.
Error found by spectre during hierarchy flattening.
    V2: Waveform type must be specified if any waveform parameters are given.
spectre terminated prematurely due to fatal error.
请问是啥个意思?在此谢过~
 楼主| 发表于 2010-1-18 09:48:47 | 显示全部楼层
没人回答一把吗?
 楼主| 发表于 2010-1-27 11:24:46 | 显示全部楼层
这都俩星期了也没人理我
发表于 2010-1-27 11:30:25 | 显示全部楼层
是用spectre时候出错的吗?
发表于 2010-5-8 19:11:18 | 显示全部楼层
1# wind2000sp3
装linux的时候要装gcc有时候model里有veriloga代码会用gcc编译
后面的问题在环境变量里
setenv CDS_Netlisting_Mode "Analog"
发表于 2010-7-26 16:08:36 | 显示全部楼层
楼主的问题解决了吗?我也遇到了类似的,怀疑是ahdl编译不通过。在rhel4下正常,到5就不行了。
发表于 2010-8-14 08:15:19 | 显示全部楼层
安装RH4时是否选择了全部安装?
发表于 2010-9-10 14:38:55 | 显示全部楼层
我也遇到同样的问题了。
请高人指点迷津~~~~~~~~~!
发表于 2010-9-14 10:02:06 | 显示全部楼层
5楼是正解,是你的gcc没有安装好,楼主贴出的文字部分已经报出是gcc相关的库找不到了。可以使用安装package的方式,勾选gcc相关的包进行安装
发表于 2010-11-26 21:42:35 | 显示全部楼层
我也是遇上同样的问题,eetop.cn下载的库,csmc05,运行.setup文件安装的,但没有提示安装gcc这一步啊!
GMT+8, 2025-12-19 23:13 , Processed in 0.024291 second(s), 6 queries , Gzip On, Redis On.
