查看: 15216|回复: 21
[求助] 安装Sentaurus TCAD软件出现的问题
发表于 2010-1-15 20:20:13 | 显示全部楼层 |阅读模式
安装Sentaurus TCAD软件出现的问题,
按照论坛上的安装方法安装之后,出现了以下问题
键入lmgrd后,出现
16:34:57 (snpslmd) Server started on localhost.localdomain for: SSS
16:34:57 (snpslmd)
16:34:57 (snpslmd) Licenses are case sensitive for TE_CATS
16:34:57 (snpslmd)
16:34:57 (lmgrd) snpslmd using TCP-port 55424
16:34:57 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  slat  ssilmd  synopsysd  tmald  vcsd
16:34:57 (snpslmd) ------------------------------------------------------------------
16:34:57 (snpslmd) Checking the integrity of the license file....
16:34:57 (snpslmd) Valid SSS feature found.
16:34:57 (snpslmd) The feature is needed to enable the other keys in your license file.
lisence程序应该是起来了吧?
[root@localhost ~]# GENESISe
***                         Sentaurus Workbench                          ***
***                          Version A-2008.09                           ***
***                        (1.4, ia32, linux_gnu)                        ***
***                       Copyright (C) 1994-2009                        ***
***                            Synopsys, Inc.                            ***
***  This software and the associated documentation are confidential     ***
***  and proprietary to Synopsys, Inc.  Your use or disclosure of this   ***
***  software is subject to the terms and conditions of a written        ***
***  license agreement between you, or your company, and Synopsys, Inc.  ***
16:35:01 (snpslmd) TCP_NODELAY NOT enabled
16:35:01 (snpslmd) UNSUPPORTED: "swb_all" (BD4C30CE542428ED00A4) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
16:35:01 (snpslmd) UNSUPPORTED: "swb_all" (PORT_AT_HOST_PLUS   ) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
16:35:01 (snpslmd) UNSUPPORTED: "SK_swb_all" (PORT_AT_HOST_PLUS   ) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
License checkout failed: License server system does not support this feature.
Feature:       swb_all
License path:  27000@localhost.localdomain
FLEXnet Licensing error:-18,147
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com"..
        * feature is "swb_all"
        * version is "2008.09"
        * server name is "localhost.localdomain"
        * daemon is "snpslmd"
        * code is "BD4C30CE542428ED00A4"
        * expiry date is "31-dec-2019"
        * STROOT is "/usr/synopsys"
        * hostname is "localhost.localdomain"
        * display is "/dev/pts/1"
        * user is "root"
[root@localhost ~]#
为什么总提示那个swb不对
那位高人帮我看看 到底出了什么问题?
头像被屏蔽
发表于 2010-1-16 13:40:32 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-1-16 20:37:21 | 显示全部楼层
显示这个后输入GENESISe应该就可以起来啊。看后面的错误信息好象还是open port number的问题,你再多检查检查,设置完注销一下,另外你的/etc/hosts 最后一行,留这个127.0.0.1  localhost.localdomain localhost 就可以了。另外可以检查一下hostname的设置是否都统一了 /etc/sysconfig/network和/etc/hosts。synipsys DC安装的时候hostname据说还不能用默认的localhost.localdomain,要改的话改成你在WIN下面PJ时候DAT文件里面的hostname好了,不过好象这个没有关系。。。
总之多试几次,反正我折腾了好久
 楼主| 发表于 2010-1-17 10:34:52 | 显示全部楼层
放弃了这个版本了,弄了一个ISE 10 , 已经搞定了
发表于 2010-6-24 16:49:26 | 显示全部楼层
楼主,可否交流ISE TCAD 10.0的CD?我有license,同时你的安装环境是red hat企业版 4.0还是5.0?
发表于 2010-10-23 20:18:26 | 显示全部楼层
回复 1# liuch23
    jjjjjjjjjjjjjjjjjj
发表于 2011-2-25 17:49:57 | 显示全部楼层
我也出现了这个问题,是redhat4安装的时候。现在改用5,还没弄好,痛苦啊。
发表于 2011-2-26 11:09:07 | 显示全部楼层
回复 7# zrunnerup
   至少你们license是好的,我用ubuntu10.10折腾了2天连license都用不成
发表于 2011-3-3 13:37:59 | 显示全部楼层
我生成的license 好象也有问题.另外环境变量不会设
发表于 2011-3-3 19:23:52 | 显示全部楼层
回复 9# liuxinghuixjtu
   这个看别人的安装攻略就行了,而且用哪个用户安装的就需要更改那个用户的环境变量,我一开始用ROOT装的也改了环境变量,用默认账号启动发现还要选重新择路径
GMT+8, 2025-9-16 02:56 , Processed in 0.023862 second(s), 5 queries , Gzip On, Redis On.
