查看: 2462|回复: 3
[招聘] 深圳 急找验证工程师和经理
发表于 2010-1-12 14:13:22 | 显示全部楼层 |阅读模式
I'm Doris-Yu,from shanghai KTHR.KTHR is a highly respected recruitment consultancy and leader in its field, delivering services to the semiconductor electronics and the telecommunication industry in Great China. Our client list contains numerous international companies, many of them are long-term customers
Now we have two job positions about verification engnineer and manager in shenzhen.
The Job Description as below
Welcome to contact me if you are  interest in it
I appreciate your help to introduce your friends for these job positions
Verification Manager
RESPONSIBILITIES:
- Lead and manage the team that develops the verification environment for USB3
Host/Device/Hubs
- Convert Requirements Documents into Schedule/Resource Plan for team
Write Test bench and Verification Modules
- Write and Debug Verification Test Cases
- Make tradeoffs between different methodologies and tools to achieve verification requirements
- Create test plans for full chip that includes complex IP
- Design and implement design verification environments
- Code test benches using System Verilog
- Utilize advanced verification tools, formal verification, emulation, and code coverage
- Generate tests and debug the Verilog design
MINIMUM REQUIREMENTS:
- BS in Electrical Engineering or Computer Science, MS preferred
- Minimum of 8 years experience in complex ASIC verification
- 3 years of management experience
- Must be strong in Verilog, Perl/Python and object oriented programming
- Must have excellent communication skills in Mandarin and English
DESIRABLE EXPERIENCE/KNOWLEDGE (should include, however not limited to):
- Directed and Random functional test environment development and use
- Experience with functional/power/performance verification using simulation and emulation environments
- Experience with HW design, simulation, verification, and HW bring-up.
IC Verification Engineer/IC 验证工程师
JOB DESCRIPTION:
-To create test plans for both block-level and chip-level according to specification
-To design and implement reusable verification environments and reference model
-To build up test cases and code test benches
QUALIFICATIONS:
- BSEE with minimum 3+year or MSEE with minimum 1-year experience of IC product development
- Proficient in verification language and tools
- Solid knowledge of ASIC design flow
- Familiar with Unix/Linux
- Good scripting skill in Perl / shell / TCL.
- Strong analytical skills, teamwork contributor and excellent communication skills
Best Regards
Doris-Yu
Shanghai Key-Team Human Resources Consulting Co.,Ltd
Add: Room F2702, SECEC, No.86 CaoBao Road, Shanghai China
Tel: (86)021-61023600-28
Mobile: 86)135 2465 4976
Fax: (86)021-61023600-19
Email:
doris-yu@kthr.com
MSN:doris_yxl@live.cn
http://www.kthr.com
发表于 2010-1-12 23:07:02 | 显示全部楼层
dddddddddddd
发表于 2010-1-24 06:48:16 | 显示全部楼层
地方不错,支持一下
发表于 2010-1-24 07:50:22 | 显示全部楼层
顶一下,城市挺好的
GMT+8, 2025-11-22 04:13 , Processed in 0.031649 second(s), 6 queries , Gzip On, Redis On.
