查看: 25315|回复: 61
[求助] Cadence SoC Encounter 8.1 (reuploaded+ Installation Movie)
发表于 2010-1-9 09:39:30 | 显示全部楼层 |阅读模式
With the Cadence® SoC Encounter™ RTL-to-GDSII System, engineers canaccount for the effects of interconnect across the entire chip—fromthe outset of the implementation cycle. It combines RTL synthesis,silicon virtual prototyping, automated floorplan synthesis, clocknetwork synthesis, design for manufacturability and yield, low-powerand mixed-signal design support, and nanometer routing. It also offersthe latest capabilities to support advanced 65nm and 45nm designs.
Features/Benefits
    * Supports multiple implementation styles with built-in power-planning, floorplanning, and signal integrity analysis
    * Supports multiple methodologies for flip-chip implementation, promoting concurrent chip/package design
    * Provides a statistical static timing analysis solution and standardized ECSM library models
    * Incorporates cutting-edge yield and low-power design capabilities
    * Handles 50M+ gate designs at 90nm and below
I reuploaded the correct image. Old files are removed.
Download:
http://rapidshare.com/files/325425951/Cadence_SoC_Encounter_8.1.7z.001
http://rapidshare.com/files/325399690/Cadence_SoC_Encounter_8.1.7z.002
http://rapidshare.com/files/325393089/Cadence_SoC_Encounter_8.1.7z.003
http://rapidshare.com/files/325407773/Cadence_SoC_Encounter_8.1.7z.004
http://rapidshare.com/files/325395283/Cadence_SoC_Encounter_8.1.7z.005
http://rapidshare.com/files/325433511/Cadence_SoC_Encounter_8.1.7z.006
http://rapidshare.com/files/325481170/Cadence_SoC_Encounter_8.1.7z.007
http://rapidshare.com/files/325401356/Cadence_SoC_Encounter_8.1.7z.008
http://rapidshare.com/files/325409273/Cadence_SoC_Encounter_8.1.7z.009
http://rapidshare.com/files/325430013/Cadence_SoC_Encounter_8.1.7z.010
http://rapidshare.com/files/325461547/Cadence_SoC_Encounter_8.1.7z.011
http://rapidshare.com/files/325464861/Cadence_SoC_Encounter_8.1.7z.012
http://rapidshare.com/files/325455779/Cadence_SoC_Encounter_8.1.7z.013
http://rapidshare.com/files/325540023/Cadence_SoC_Encounter_8.1.7z.014
http://rapidshare.com/files/325466965/Cadence_SoC_Encounter_8.1.7z.015
http://rapidshare.com/files/325471544/Cadence_SoC_Encounter_8.1.7z.016
http://rapidshare.com/files/325475343/Cadence_SoC_Encounter_8.1.7z.017
http://rapidshare.com/files/325483554/Cadence_SoC_Encounter_8.1.7z.018
http://rapidshare.com/files/325506887/Cadence_SoC_Encounter_8.1.7z.019
http://rapidshare.com/files/325500858/Cadence_SoC_Encounter_8.1.7z.020
http://rapidshare.com/files/325512054/Cadence_SoC_Encounter_8.1.7z.021
http://rapidshare.com/files/325528108/Cadence_SoC_Encounter_8.1.7z.022
http://rapidshare.com/files/325520799/Cadence_SoC_Encounter_8.1.7z.023
http://rapidshare.com/files/325539321/Cadence_SoC_Encounter_8.1.7z.024
http://rapidshare.com/files/325531564/Cadence_SoC_Encounter_8.1.7z.025
http://rapidshare.com/files/325524429/Cadence_SoC_Encounter_8.1.7z.026
http://rapidshare.com/files/325527652/Cadence_SoC_Encounter_8.1.7z.027
http://rapidshare.com/files/325536269/Cadence_SoC_Encounter_8.1.7z.028
http://rapidshare.com/files/325540232/Cadence_SoC_Encounter_8.1.7z.029
http://rapidshare.com/files/325373481/Cadence_SoC_Encounter_8.1.7z.030
How to install (movie):
http://rapidshare.com/files/327698284/Install_SOC_Encounter_on_Debian_5.7z
Password:
mj
video
http://www.viddler.com/explore/RobertDwyer/videos/16/
发表于 2010-1-15 12:04:54 | 显示全部楼层
it is very nice!!!  thanks a lot
发表于 2010-1-20 23:01:22 | 显示全部楼层
太好了,终于能下了
发表于 2010-1-23 00:19:15 | 显示全部楼层
I must say "thank you" three times for LZ. You are really a kind people.
发表于 2010-1-28 18:09:07 | 显示全部楼层
感謝!
感謝!
感謝!
個人用心與貢獻.
國家競爭力提升.
发表于 2010-2-4 16:18:32 | 显示全部楼层
Thanks!
发表于 2010-2-8 21:21:39 | 显示全部楼层
thank you .................
发表于 2010-2-11 22:24:14 | 显示全部楼层
ddddddd
发表于 2010-2-11 22:42:01 | 显示全部楼层
too hard to install
发表于 2010-3-7 08:49:48 | 显示全部楼层
Thanks
GMT+8, 2025-12-25 01:11 , Processed in 0.019880 second(s), 3 queries , Gzip On, Redis On.
