查看: 26412|回复: 55
Does any one know how to generate a Cadence working license using EFA kit ?
发表于 2010-1-9 09:01:54 | 显示全部楼层 |阅读模式
Someone posted how to generate Novas and Synopsys licenses files
Is there a way to generate Cadence working license for flexlm 10.2 ?
发表于 2010-1-9 09:49:26 | 显示全部楼层
This is new efa packs for ALL cadence feature (5.1.41). copy file Cadence_Design_Systems_71.lpd and Cadence_Design_Systems_71.src in /EFA_LicGen_0.4b/packs . then run LicGen.exe -> Open ->Cadence Design Systems_71.lpd.
Options:
1)Select Host Id - any
2)Select Use Daemon - any
run Generate and save file as license.dat
Then use this license file, just set your CDS_LIC_FILE point to it.
(setenv CDS_LIC_FILE ~/Desktop/license.dat)
DO NOT use it with a lmgrd!!!!
Efa_packs.rar
4.16 KB, 下载次数: 423 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-1-9 10:09:11 | 显示全部楼层
All the new Cadence software use FLEXlm 10.xxx with ECC sign2.
The old EFA doesn't work any more
发表于 2010-1-9 12:31:04 | 显示全部楼层
应该需要pj软件的吧?
发表于 2010-1-9 12:33:48 | 显示全部楼层
2楼那是固定license?
 楼主| 发表于 2010-1-10 01:49:00 | 显示全部楼层
Push by myself
发表于 2010-1-16 11:52:54 | 显示全部楼层
thanks......
发表于 2010-3-18 12:21:40 | 显示全部楼层
thanks ......
发表于 2010-3-20 15:52:51 | 显示全部楼层
Thanks
发表于 2010-4-11 22:11:08 | 显示全部楼层
تشچر
GMT+8, 2025-12-15 01:24 , Processed in 0.029279 second(s), 7 queries , Gzip On, Redis On.
