查看: 3262|回复: 1
[求助] 请问下这是什么错误?谢谢~~~
发表于 2009-12-30 17:36:06 | 显示全部楼层 |阅读模式
ERROR : Place:1063 - The delay controller "U_pp/top0/DATA_PATH_0/TAPLOGIC_0/IDELAYCTRL1" has been locked with the following location constraint: COMP "U_pp/top0/DATA_PATH_0/TAPLOGIC_0/IDELAYCTRL1" LOCATE = SITE "IDELAYCTRL_X2Y6" LEVEL 1 However, none of the delay elements calibrated by this controller are being used. The delay controller should be removed from the design and the net "U_pp/top0/DATA_PATH_0/TAPLOGIC_0/idelay_ctrl_rdy1" should be connected to GLOBAL_LOGIC_1. Please correct your design and rerun. 意思是说我虽然约束了IDELAYCTRL,但是在设计中却没有使用么?
发表于 2009-12-31 17:16:42 | 显示全部楼层
It looks like you are using FPGA.
The message says your "delay" element is no use.
Tool suggests you to remove that element and rerun
again.
GMT+8, 2025-12-25 14:48 , Processed in 0.014521 second(s), 7 queries , Gzip On, Redis On.
