查看: 16640|回复: 44
[原创] GGNMOS as ESD device
发表于 2009-12-26 18:28:46 | 显示全部楼层 |阅读模式
i wrote a paper about Gate grounded NMOS as ESD protection device in Chinese. it's very basic but worths you to spend a couple of minuites to review. isn't it?
you are welcome to discuss any related question with me.
GGNMOS.pdf
669.85 KB, 下载次数: 506 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-12-26 21:42:28 | 显示全部楼层
Good guy;
发表于 2009-12-28 09:11:55 | 显示全部楼层
thanks
发表于 2009-12-28 09:42:44 | 显示全部楼层
ddddddddddddd
发表于 2009-12-29 21:42:24 | 显示全部楼层
摘要有嘛?
发表于 2009-12-29 22:48:52 | 显示全部楼层
论文还是书??
发表于 2009-12-30 00:17:32 | 显示全部楼层
thank!
 楼主| 发表于 2009-12-30 09:57:23 | 显示全部楼层
6# twfly
论文
 楼主| 发表于 2009-12-30 10:02:35 | 显示全部楼层
摘要:本文基于某0.18μm‐CMOS 工艺制程的1.8V NMOS 器件,从工艺的角度并用TLP测试系统对栅极接地的NMOS(GGNMOS)ESD 器件进行比较分析。介绍了SAB 和ESD 注入对GGNMOS的性能影响。影响GGNMOSESD 性能的瓶颈是均匀开启性。在GGNMOS 版图等其它特征参数最优的前提下,采用SAB 能改善其均匀开启性,从而大大改进ESD性能。GGNMOS 的瞬态触发电压在7V 左右,不会造成栅氧可靠性威胁,采用PESD 并非必须。
发表于 2010-2-3 13:34:14 | 显示全部楼层
thank for sharing
GMT+8, 2025-12-14 15:57 , Processed in 0.032836 second(s), 9 queries , Gzip On, Redis On.
