查看: 11181|回复: 16
[求助] formality 求助
发表于 2009-12-23 21:16:02 | 显示全部楼层 |阅读模式
我在进行综合后RTL与网表形式验证,当读入了RTL代码和db后,set top竟然出错(网表还没读入呢)
Error: RTL interpretation messages were produced during link.
        Verification results may disagree with a logic simulator. (FM-089)
Error: Failed to set top design to 'r:/WORK/can_top' (FM-156)
0
这是怎么回事呢,请高手指教一下,不甚感激!
发表于 2009-12-25 00:38:07 | 显示全部楼层
可能是代码有问题。
从formality的文档里抄出来的:
FM-089 (error) RTL interpretation messages were produced during %s. Verification results may disagree with a logic simulator.
DESCRIPTION
Your simulation and verification results differ. These differences occur when a logic simulator and Formality do not interpret your HDL source code in exactly the same way.
WHAT NEXT
Modify your HDL source code according to the Synopsys HDL source development standards or use the "hdlin_warn_on_mismatch_message" variable to treat the message as a warning instead of an error.
应该可以用>man FM-089看到的。
家里没有软件,没试。
 楼主| 发表于 2009-12-28 16:51:00 | 显示全部楼层
谢谢,
发表于 2009-12-30 22:14:42 | 显示全部楼层
发表于 2010-5-12 14:49:01 | 显示全部楼层
虚心学习
发表于 2010-5-27 23:34:18 | 显示全部楼层
学习了
发表于 2010-6-3 09:22:24 | 显示全部楼层
看是不是库没有读对
发表于 2010-6-3 09:24:46 | 显示全部楼层
永远都学习不完,这个东东
发表于 2010-8-23 19:15:18 | 显示全部楼层
那确实是 啊
发表于 2010-8-25 16:00:58 | 显示全部楼层
把错误代码(FM-089)设为warning级别的,再试试!
GMT+8, 2025-12-28 08:24 , Processed in 0.028176 second(s), 7 queries , Gzip On, Redis On.
