楼主: lowpowerdesign
[招聘] [LSI]高手的春天--Digital IC/ASIC Engineer, Sept.27,2010更新
发表于 2010-1-27 16:32:35 | 显示全部楼层
LSI吗?
 楼主| 发表于 2010-1-28 07:01:10 | 显示全部楼层
欢迎继续申请!!
这么早来顶贴不容易啊
 楼主| 发表于 2010-1-28 19:45:32 | 显示全部楼层
有人问今年三四月会不会有招聘高峰
这个很难说
不过我们公司的招聘一直在进行,而且开了很多岗位
 楼主| 发表于 2010-1-29 11:13:26 | 显示全部楼层
我竟然升金领了!
发表于 2010-1-29 16:53:59 | 显示全部楼层
xiwang ni
 楼主| 发表于 2010-1-30 22:29:52 | 显示全部楼层
顶!!
 楼主| 发表于 2010-2-1 10:21:05 | 显示全部楼层
暂时没有回复不要紧
可以给我发email,我会去问的
发表于 2010-2-1 15:40:01 | 显示全部楼层
lowpowerdesign
 楼主| 发表于 2010-2-2 10:52:41 | 显示全部楼层
感觉公司的招聘要求高了起来,还有不少职位空缺的
按理来说也收到不少简历啊
 楼主| 发表于 2010-2-2 10:56:03 | 显示全部楼层
Custom Layout Engineer
LSI's Storage Peripherals Group is looking for an experienced IC physical design engineer to join the pre-amplifier design team. As a preamp physical design (layout) engineer you will work closely with circuit design to implement high-speed custom analog designs and develop mask layouts for customer products. You will join a cross-functional team responsible for developing leading edge high-speed magneto electronic read/write IC products that ultimately achieve high volume production.
- Layout high speed analog and mixed-signal custom chips for the hard disk drive industry
- Work directly with a team of engineers to determine floor plan, routing and I/O requirements for preamp IC's
- Perform IC design rule and connectivity verification and drive products through mask
release flows.
- Contribute to methodology improvements to increase layout and verification efficiency.
PREFERRED EXPERIENCE:
- Bachelor's degree in Electrical Engineering (or related field) or equivalent experience
- Minimum three to five years experience in custom analog IC physical design
- Experience with schematic-driven layout, floor planning, chip level routing, design for
manufacturing and design rule and connectivity verification is required
- Experience using Cadence Virtuoso XL and VCAR router preferred
- Familiarity with both analog and digital layout tools and flows, circuit design concepts and
IC manufacturing processes desired
GMT+8, 2025-12-28 12:52 , Processed in 0.017183 second(s), 3 queries , Gzip On, Redis On.
