查看: 32156|回复: 74
MIT教材《微电子器件与电路》,终于找到了!
发表于 2009-12-12 02:50:44 | 显示全部楼层 |阅读模式
LEC #TOPICSREADINGS16.012 outline: grading, ethics
Overview of semiconductor applications, silicon integrated circuit technology
2.52Intrinsic semiconductors, electrons and holes, bond model, generation recombination and thermal equilibrium; doping, donors, acceptors, compensation2.1-2.23Carrier transport, drift velocity, drift current density, diffusion current density2.44The p-n junction, carrier concentration and potential in thermal equilibrium, 60mV rule3.2-3.35The p-n junction in thermal equilibrium3.46Introduction to the MOS structure, MOS capacitor in thermal equilibrium3.77MOS capacitor under applied bias; accumulation, depletion, and inversion regions3.88MOSFET physical structure, circuit symbol and terminal characteristics, MOS transistor characteristics4.1-4.39MOS transistor, backgate effect, MOSFET in saturation4.410MOSFET small-signal model4.511Digital logic concepts, inverter characteristics, logic levels and noise margins, transient characteristics, inverter circuits, NMOS/resistor loads5.1-5.212NMOS/current source load, CMOS inverter, static analysis5.3-5.413CMOS inverter, propagation delay model, static CMOS gates5.514p-n junction diode terminal characteristics, minority carrier concentration under forward and reverse bias6.1-6.315Short base approximation, steady state diffusion equation with currents in p-n junction6.316p-n junction diode circuit model, large signal static model, small signal model, diffusion capacitance6.417Introduction of bipolar junction transistor, terminal characteristics, forward active bias, current gain7.1-7.218Reverse active mode and saturation, the Ebers-Moll model7.3-7.419Single stage amplifiers, two port small signal model, common source amplifier with resistor and current source supply8.1-8.620Common base/gate amplifier, common collector/drain8.8-8.921Review frequency domain analysis; current gain frequency response of common emitter amplifier10.1-10.322Voltage gain frequency response of common emitter amplifier, full analysis of common emitter, the Miller approximation10.423Open circuit time constant analysis, common-gate (CG) and common-drain (CD) amplifiers10.5-10.624Multistage amplifiers, cascading small signal two port models9.1-9.225DC coupling, voltage sources, MOS current sources, current sources and sinks9.426Analyzing complex circuits and course wrap-up9.6 and 10.7
Microelectronic Devices and Circuits.part01.rar
3.81 MB, 下载次数: 266 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Microelectronic Devices and Circuits.part02.rar
3.81 MB, 下载次数: 249 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Microelectronic Devices and Circuits.part03.rar
3.81 MB, 下载次数: 338 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Microelectronic Devices and Circuits.part04.rar
3.81 MB, 下载次数: 222 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Microelectronic Devices and Circuits.part05.rar
3.81 MB, 下载次数: 224 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Microelectronic Devices and Circuits.part06.rar
3.81 MB, 下载次数: 163 , 下载积分: 资产 -2 信元, 下载支出 2 信元
3.81 MB, 下载次数: 139 , 下载积分: 资产 -2 信元, 下载支出 2 信元
3.81 MB, 下载次数: 1616 , 下载积分: 资产 -2 信元, 下载支出 2 信元
3.81 MB, 下载次数: 141 , 下载积分: 资产 -2 信元, 下载支出 2 信元
3.81 MB, 下载次数: 213 , 下载积分: 资产 -2 信元, 下载支出 2 信元
3.81 MB, 下载次数: 156 , 下载积分: 资产 -2 信元, 下载支出 2 信元
3.81 MB, 下载次数: 362 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Microelectronic Devices and Circuits.part07.rar
3.81 MB, 下载次数: 305 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Microelectronic Devices and Circuits.part08.rar
3.81 MB, 下载次数: 405 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Microelectronic Devices and Circuits.part09.rar
2.33 MB, 下载次数: 512 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-12-12 02:52:56 | 显示全部楼层
注意,part1----part6重复了,下载一次即可,共九个部分。
 楼主| 发表于 2009-12-12 02:54:49 | 显示全部楼层
MIT 6.012 Microelectronic Devices and Circuits课程用了很多年的经典教材。
发表于 2009-12-12 06:50:09 | 显示全部楼层
make money?
发表于 2009-12-12 08:04:43 | 显示全部楼层
以前我是每天看贴无数,基本不回贴. 后来发现这样很傻,水平不见涨啊! 于是我就学习前辈,把这段文字保存在记事本里; 看到好贴就复制粘贴一次. 顺便帮LZ把贴子顶上去 !!!
回复 支持 0 反对 1
发表于 2009-12-12 09:56:51 | 显示全部楼层
thanks
发表于 2009-12-12 10:27:43 | 显示全部楼层
多谢楼主,下来看看
发表于 2009-12-12 17:52:28 | 显示全部楼层
thanks
发表于 2009-12-12 23:05:29 | 显示全部楼层
xiexie
发表于 2009-12-12 23:51:38 | 显示全部楼层
kankan
GMT+8, 2025-12-19 07:37 , Processed in 0.023859 second(s), 5 queries , Gzip On, Redis On.
