查看: 5268|回复: 7
LDV 安装问题
发表于 2009-12-4 13:47:26 | 显示全部楼层 |阅读模式
在进行LDV安装后进行verilog仿真时提示;Invalid verilog executable /edatool/cadence/IC5141/tools.inx86/dfll/bin/verilog.exe我装了LDV但是怎么执行路径到了ic5141中呢/,这个究竟是啥问题?哪位大侠指导下。
发表于 2009-12-4 14:07:08 | 显示全部楼层
you can type "which verilog" on the command prompt, look the path to points, maybe as your path environment make the mistake.
发表于 2009-12-4 15:25:55 | 显示全部楼层
多谢!!!!!!!!
 楼主| 发表于 2009-12-15 15:11:56 | 显示全部楼层
the problem has been soluted .Thanks
发表于 2009-12-18 22:01:45 | 显示全部楼层
Thanks
发表于 2010-1-25 09:09:39 | 显示全部楼层
有使用教程吗
发表于 2010-6-19 18:41:23 | 显示全部楼层
thanks for sharing
发表于 2014-7-24 23:14:58 | 显示全部楼层
GMT+8, 2025-12-19 17:11 , Processed in 0.025841 second(s), 5 queries , Gzip On, Redis On.
