查看: 4130|回复: 5
sentaurus安装问题
发表于 2009-11-26 17:11:50 | 显示全部楼层 |阅读模式
在rad hat9.0下安装sentaurus出现的问题,请高手帮我解决,谢谢!
Installing linux code for product sentaurus
Create site_info...
Installation failed
      Installation has finished but with error. Check the installation
      log /eda/synopsys/install/install.log for details.
Synopsys tools require that a supported version of Synopsys Common
Licensing (SCL) be installed and serving the necessary licenses.
For information on how to obtain SCL, or your license key file,
see http://www.synopsys.com/keys
For any postinstallation setup requirements, see the product-specific
chapters in the Installation Guide at http://www.synopsys.com/install
To receive timely Synopsys support on tool related issues, you must
install ViewConnect support software along with other Synopsys tools.
If you have not yet installed ViewConnect, go to
https://solvnet.synopsys.com/viewconnect#d to download and install the
required binary files.
发表于 2009-12-22 13:42:03 | 显示全部楼层
same issue help us
发表于 2009-12-22 16:08:45 | 显示全部楼层
搞定了,没有 用 2.0 setup.sh。全解压就可以了。
发表于 2010-10-12 23:08:04 | 显示全部楼层
看看先
发表于 2010-10-23 20:08:35 | 显示全部楼层
回复 1# leiyuming
    kkkkkkkk
发表于 2012-1-30 13:22:16 | 显示全部楼层
redhat 9.0成功了吗?
GMT+8, 2025-12-26 20:39 , Processed in 0.020842 second(s), 8 queries , Gzip On, Redis On.
