查看: 5603|回复: 1
关于ALTSYNCRAM和ALTDPRAM的异同?
发表于 2009-11-26 15:31:48 | 显示全部楼层 |阅读模式
The ports and parameters details are important if you bypass the MegaWizard Plug-In Manager interface and use the megafunction as a directly parameterized instantiation in your design. The details of the parameters are hidden from the MegaWizard Plug-In Manager interface.
Altera recommends you to use ALTSYNCRAM megafunction to build synchronous memory function for single-port RAM, dual-port RAM, single-port ROM, and dual-port ROM. Use ALTDPRAM megafunction if you want to create a asynchronous read dual-port RAM support.
谁能解释一下这段话的大概意思啊。。。ALTSYNCRAM和ALTDPRAM的区别有哪些?
因为本人对于IP核一般都是通过MegaWizard Plug-In Manager生成然后使用的,难道可以不通过MegaWizard Plug-In Manager直接调用么?
 楼主| 发表于 2009-11-27 08:28:04 | 显示全部楼层
都没有人了解的么。。。呜呜。。。
GMT+8, 2025-12-26 10:56 , Processed in 0.017102 second(s), 7 queries , Gzip On, Redis On.
