楼主: braudel
spectre 问题,急
发表于 2009-11-23 23:59:35 | 显示全部楼层
没有用过ic610
发表于 2009-11-25 16:09:57 | 显示全部楼层
重装一次,实在不行,还是用5141的 呗,稳定!!!
发表于 2009-11-26 20:42:31 | 显示全部楼层
估计是库glibc的兼容性问题, 你使用的操作系统和glibc版本是什么?  可以换个系统试试
发表于 2009-12-8 23:21:05 | 显示全部楼层
我也出现了同样的问题 不知道如何解决啊
发表于 2009-12-10 18:47:23 | 显示全部楼层
I also face this issue before but now solved...
From my experience, this problems not related to the cadence software itself or installation error, but is due to hardware.
Previously I use AMD Athlon X2 7750 BE and MSI K9A2 Neo2 motherboard.
I test the MMSIM6.1 and MMSIM7.0 in REHL3 (Base, Update 3, Update 4) and REHL4 (Base, Update 7), it come out Internal Error, Segmentation Fault (same errors as you face now).
And I found that MMSIM7.11.071 will solve the problems, but due to lic3nce issue, I didn't use it.
Now I downgrading my PC to AMD Athlon X2 5000+, everything OK.....
I not sure whether is CPU Virtualization issue or not.
Hope somebody can give some opinions.
For my suggestion, you can try using MMSIM7.11.071 first, crack lic3nce also can found in eetop.
Note: I just explain base on my previous experience, I might be wrong...
发表于 2009-12-11 13:41:01 | 显示全部楼层
检查硬件环境,是不是新的AMD双核?
虚拟机?
发表于 2009-12-11 14:57:44 | 显示全部楼层
IC61有人用吗?
发表于 2009-12-11 15:12:50 | 显示全部楼层
严格按照教程的步骤哦,你检查一下环境变量设置和license吧,网上很多安装教程的
发表于 2009-12-13 21:19:42 | 显示全部楼层
ic610比5141好很多么?
发表于 2010-11-20 21:35:50 | 显示全部楼层
我也遇到这样的情况,哪位高人能帮我们解答下,谢谢。
GMT+8, 2025-12-26 19:13 , Processed in 0.017444 second(s), 3 queries , Gzip On, Redis On.
