楼主: alcohol
laker 32v4 new SRC and LPD
发表于 2009-11-4 09:22:46 | 显示全部楼层
这是最近最好的贴了
不知道会不会在编辑状态运行一段时间自动退出或报错!!!
发表于 2009-11-4 14:34:27 | 显示全部楼层
thanks!
发表于 2009-11-4 16:31:34 | 显示全部楼层
*ERROR* License Error: 0x3ec, Contact customer support. Program will now exit.
stack trace not available
Process exit with status code of 1
Above call-stack dumped because process called exit with a value other than 0
For debugging purposes. No coredump signal raised.
楼主,还是有问题啊,运行半小时出现的!!!
发表于 2009-11-4 17:53:10 | 显示全部楼层
good   thanks !!!!!!!!!!
 楼主| 发表于 2009-11-4 18:22:42 | 显示全部楼层
hi  qxj321 :
        sorry  which license daemon ?
        I run Laker L3 a few hours is no problem //
        may i ask   your  OS version and HW spec ?
I can try solve
sorry again
 楼主| 发表于 2009-11-4 18:24:02 | 显示全部楼层
Use  Redhat ES4  //  AMD dual cpu M2E main board  1 G ram
that all //
发表于 2009-11-5 08:20:13 | 显示全部楼层
呵呵,感谢楼主,我虚拟机OS: AS4测试的,编辑状态下,Laker_ADP半小时出现问题的,Laker_FPD两小时多!!!!
期待!!!THX!!
发表于 2009-11-5 10:45:48 | 显示全部楼层
谢谢分享
发表于 2009-11-8 20:58:35 | 显示全部楼层
多謝分享,用看看
发表于 2009-11-12 17:42:17 | 显示全部楼层
要用efa4么?
GMT+8, 2025-12-14 18:18 , Processed in 0.017701 second(s), 3 queries , Gzip On, Redis On.
