查看: 3143|回复: 2
美资公司诚聘Analog Design/verifiction Engineer
发表于 2009-11-2 20:09:16 | 显示全部楼层 |阅读模式
美资公司 LSI 上海研发中心高薪诚聘存储通讯领域人才,薪水待遇优厚,部分人员有出国培训机会。(部门内部推荐)
有意者请将中英文简历发送至:asic_tapeout@hotmail.com
Analog Design Engineer
City :  Shanghai
DESCRIPTION OF DUTIES IN ADDITION TO THOSE IN JOB DESCRIPTION:
- Design high speed analog and mixed-signal integrated circuits within custom chips for the hard disk drive industry
- Work directly with customers to determine system requirements, write specifications and guide customers in the use of pre-amplifier products
- Use high speed electronic characterization equipment to evaluate and debug the functionality of the design once the part is fabricated in silicon
- Provide technical leadership through all phases of product development including test, yield, characterization, reliability analysis, qualification and release to manufacturing
PREFERRED EXPERIENCE:
LSI's Storage Peripherals Group is looking for an experienced custom analog IC designer to join the pre-amplifier design team. At LSI we are committed to innovation and industry leadership. We develop advanced high-speed magneto electronic read/write IC architectures as the basis for our products.
Design team members define, create and modify high-speed custom integrated circuits for hard disk drive (HDD) products using leading edge CMOS and SiGe BiCMOS technologies. Team members support the entire product life cycle beginning with design and moving through test, qualification, release to production and ramp to volume.
- Degree in Electrical Engineering (or related field), MS required, Ph.D. preferred
- Minimum three to five years experience in discrete, transistor level analog circuit design
- Experience with analog and mixed signal IC product design, integration and verification is required
- Strong physical layout knowledge and parasitic component understanding essential
- Process and device physics knowledge critical
- Proven skills using electronic measurement equipment in a lab environment
- Expertise in applied magnetism and recording a strong plus
发表于 2010-1-24 13:00:17 | 显示全部楼层
看看。。。
发表于 2010-1-24 22:52:09 | 显示全部楼层
dddddddddddd
GMT+8, 2025-10-5 09:53 , Processed in 0.017933 second(s), 6 queries , Gzip On, Redis On.
