查看: 4389|回复: 3
在IC5141上做Hspice 仿真很严重的问题。救命!!
发表于 2009-10-16 10:33:38 | 显示全部楼层 |阅读模式
我装了本站的Hspice 2006 9 linux. 因为只有它的license 支持 psf  sda 和 cdsaawave. 然后运行Hspice 仿真。结果发现, 产生了hspice 产生了netlist 但是wavescan 画不出图来。 同样的电路那spectreS 一点问题都没有。 希望牛人来帮我解决。 错误如下。 解决有赏。 另外求,Hspice 2007 3 linux.和 Hspice 2008 3 带 psf  sda 和 cdsaawave 的license
HSPICE FINISHED
elapsed time 1 S
...successful.
reading simulation data...
...successful.
*Error* Trying to plot expression <IS("/V2/PLUS" "/root/simulation/tb_INV_2/hspiceS/schematic")>, which does not evaluate to an object that can be plotted, like waveform or parametric wave. Please refer to the Wavescan User Guide to see what all types of objects can be plotted in Wavescan. Expression which evaluates to only those type(s) of objects can be plotted.
*WARNING* (reader): string terminated by illegal char \000 at line 9 of file /root/simulation/tb_INV_2/hspiceS/schematic/psf/logFile
"raw/tb_INV_2.sw0SYNTAX ERROR found at line 9 column 18 of file /root/simulation/tb_INV_2/hspiceS/schematic/psf/logFile
 楼主| 发表于 2009-10-17 08:56:11 | 显示全部楼层
top top
发表于 2009-11-10 10:36:08 | 显示全部楼层
我也遇到了同样的问题,谁能解决一下啊,谢谢~~~~~
发表于 2010-6-23 17:41:26 | 显示全部楼层
一样的问题,求助了
GMT+8, 2025-12-18 11:14 , Processed in 0.027879 second(s), 5 queries , Gzip On, Redis On.
