发表于 2010-10-24 13:41:39
显示全部楼层
tools$ ./patch_encounter32
[total hits/matching patterns/non-matching patterns]
warn : empty file: perl/lib/5.8.0/i686-linux/auto/threads/shared/shared.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/threads/threads.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/KR/KR.bs - skipping
67% perl/lib/5.8.0/i686-linux/auto/Encode/KR/KR.so : 0warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/JP/JP.bs - skipping
66% perl/lib/5.8.0/iwarn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/Byte/Byte.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/CN/CN.bs - skipping
5warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/Symbol/Symbol.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/Encode.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/EBCDIC/EBCDIC.bs - skipping
67% perl/lib/5.8.0/i686-linux/auto/Encode/TW/TW.sowarn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/TW/TW.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/Unicode/Unicode.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/ODBM_File/ODBM_File.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Socket/Socket.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Devel/PPPort/PPPort.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Devel/DProf/DProf.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Devel/Peek/Peek.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Digest/MD5/MD5.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/GDBM_File/GDBM_File.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/MIME/Base64/Base64.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Fcntl/Fcntl.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/NDBM_File/NDBM_File.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Filter/Util/Call/Call.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/re/re.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Sys/Hostname/Hostname.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Sys/Syslog/Syslog.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/ByteLoader/ByteLoader.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/List/Util/Util.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/POSIX/POSIX.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/attrs/attrs.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/I18N/Langinfo/Langinfo.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/PerlIO/encoding/encoding.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/PerlIO/via/via.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/PerlIO/scalar/scalar.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Time/HiRes/HiRes.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/IPC/SysV/SysV.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/SDBM_File/SDBM_File.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/IO/IO.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Data/Dumper/Dumper.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/B/B.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/B/C/C.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Cwd/Cwd.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Unicode/Normalize/Normalize.bs - skipping
55% ...lib/5.8.0/i686-linux/auto/Unicode/Normalize/Normalize.so warn : empty file: perl/lib/5.8.0/i686-linux/auto/XS/APItest/APItest.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/XS/Typemap/Typemap.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/File/Glob/Glob.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Storable/Storable.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Opcode/Opcode.bs - skipping
[001/1/0] celtic/bin/32bit/make_cdb
[001/1/0] bin/cdsmps
[001/1/0] bin/ckout_test
[001/1/0] bin/stampEncrypt
[002/1/0] simvision/bin/comparescan.exe
[001/1/0] simvision/bin/simvision.exe
[001/1/0] simvision/bin/simvisdbutil.exe
[001/1/0] spectre/bin/32bit/spectre_reader
[001/1/0] spectre/bin/32bit/spectre_encrypt
[001/1/0] spectre/bin/32bit/cmiGet
[001/1/0] extraction/bin/32bit/nebulamesh
[001/1/0] extraction/bin/32bit/geom
[001/1/0] extraction/bin/32bit/etoxy
[001/1/0] extraction/bin/32bit/epick
[001/1/0] extraction/bin/32bit/sip
[001/1/0] extraction/bin/32bit/emerge
[001/1/0] extraction/bin/32bit/grow
[001/1/0] extraction/bin/32bit/mergecap
[001/1/0] extraction/bin/32bit/pax16
[001/1/0] fe/bin/32bit/viewlog
[001/1/0] fe/bin/32bit/sroute
[009/1/0] fe/bin/32bit/generateCapTbl
[001/1/0] fe/bin/32bit/wroute
[003/1/0] inca/bin/ncdc
[001/1/0] inca/bin/ncxlimport
[004/1/0] inca/bin/ncelab
[001/1/0] inca/bin/ncvlog_cg
[002/1/0] inca/bin/ncvlog
[001/1/0] inca/bin/ncupdate
[001/1/0] inca/bin/ncgentb
[001/1/0] inca/bin/ncsdfc
[001/1/0] inca/bin/ncshell
[001/1/0] inca/bin/ncls
[004/1/0] inca/lib/ncelab.o
[001/1/0] 1/sfk
[001/1/0] tlfUtil/bin/tlfMerge
[001/1/0] tlfUtil/bin/tlfConvert
[001/1/0] tlfUtil/bin/tlfEncrypt
[002/1/0] sev/bin/32bit/coyote
[001/1/0] plato/bin/32bit/nanoroute
71% lib/libstdc++.so.error: failed to read+write: lib/SuSE/libgdbm.so.2 - skipping
[001/1/0] synth/bin/32bit/rcl
[001/1/0] makedpm/bin/32bit/makedpm
96% makedpmerror: failed to read+write: sfk - skipping
[001/1/0] catena/bin/32bit/db_check
[001/1/0] catena/bin/32bit/finaleXTS
55% perl-5.8.8/lib/5.8.8/podwarn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/threads/shared/shared.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/threads/threads.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/KR/KR.bs - skipping
41% perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/JP/JP.bs - skipping
37% perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/Byte/Byte.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/CN/CN.bs - skipping
85% pwarn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/Symbol/Symbol.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/Encode.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/EBCDIC/EBCDIC.bs - skipping
79% perl-5.8.8/lib/5.8.8/i686-linux/autowarn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/TW/TW.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/Unicode/Unicode.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Socket/Socket.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Devel/PPPort/PPPort.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Devel/DProf/DProf.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Devel/Peek/Peek.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Digest/MD5/MD5.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/GDBM_File/GDBM_File.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/MIME/Base64/Base64.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Fcntl/Fcntl.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/NDBM_File/NDBM_File.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Filter/Util/Call/Call.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/re/re.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Sys/Hostname/Hostname.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Sys/Syslog/Syslog.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/ByteLoader/ByteLoader.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/List/Util/Util.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/POSIX/POSIX.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/attrs/attrs.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/I18N/Langinfo/Langinfo.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/PerlIO/encoding/encoding.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/PerlIO/via/via.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/PerlIO/scalar/scalar.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Time/HiRes/HiRes.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/IPC/SysV/SysV.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/SDBM_File/SDBM_File.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/IO/IO.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Data/Dumper/Dumper.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/B/B.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/B/C/C.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Cwd/Cwd.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Unicode/Normalize/Normalize.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/XS/APItest/APItest.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/XS/Typemap/Typemap.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/File/Glob/Glob.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Storable/Storable.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Opcode/Opcode.bs - skipping
[001/1/0] fms/bin/32bit/flowMgr
[001/1/0] anls/bin/32bit/thunder.tty
[001/1/0] anls/bin/32bit/lightning
[001/1/0] anls/bin/32bit/tablegen
[001/1/0] anls/bin/32bit/itaputil
[001/1/0] anls/bin/32bit/libgen
[001/1/0] anls/bin/32bit/rcx2pgdb
[001/1/0] anls/bin/32bit/thunder2spice
[001/1/0] anls/bin/32bit/lightning.tty
[001/1/0] anls/bin/32bit/mergenet
[001/1/0] anls/bin/32bit/mergegrid
[001/1/0] anls/bin/32bit/zx
[001/1/0] anls/bin/32bit/vstorm2
[001/1/0] anls/bin/32bit/powermeter
[001/1/0] anls/bin/32bit/storm
[001/1/0] anls/bin/32bit/xtc
[005/1/0] anls/bin/32bit/stitcher
[001/1/0] anls/bin/32bit/psviewer
warn : cannot read: leplugin.so : 0 changes
18044 files checked, 66 changed.
2 errors, 94 warnings occurred. |
