查看: 5603|回复: 2
LTE Channel Vs Transmission Vs Occupied bandwidth?
发表于 2009-10-12 18:09:37 | 显示全部楼层 |阅读模式
Dear all,
From the 3GPP document, I find three terms: (1) Channel Bandwidth, (2) Transmission bandwidth and (3) Occupied bandwidth.
From the 3GPP document stated that Channel bandwidth=1.4MHz. Then the Transmission bandwidth configuration NRB=6. Based on the calculation, Transmission bandwidth = 6 * 15kHz * 12 = 1.08MHz. Now, I have a question. Based on these two values, does "transmission bandwidth" is the bandwidth contain all necessary data and need to cover in the circuit design?
"Channel bandwidth" is the bandwidth just for frequency planning only?
From the 3GPP document stated that Occupied bandwidth is defined as the bandwidth containing 99% of the total integrated mean power of the transmitted spectrum on the assigned channel. Then what is the relationship with Channel and Transmission bandwidth? I am not clear of it. I hope someone could answer it.
thanks
发表于 2009-11-6 22:18:16 | 显示全部楼层
1# smartchi
Pls refer to 3GPP 36.104Figure 5.6-1 Definition of Channel Bandwidth andTransmission Bandwidth Configuration for one E‑UTRA carrier
头像被屏蔽
发表于 2010-1-23 21:07:30 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-9-13 10:56 , Processed in 0.017631 second(s), 6 queries , Gzip On, Redis On.
