查看: 3184|回复: 3
TD-LTE dynamic range definition
发表于 2009-10-9 11:08:11 | 显示全部楼层 |阅读模式
Dear all,
I have a question about the dynamic range definition. For 5MHz channel spacing, the dynamic range is 75dB. I have seen some transmitter architechture, it always uses external Power Amplifier. Then, the dynamic range = 75dB does consist of this external power amplifier? Or, this 75dB just count in all on-chip circuit only?
Thanks
smartchi
发表于 2009-10-13 09:12:20 | 显示全部楼层
Dear all,
I have a question about the dynamic range definition. For 5MHz channel spacing, the dynamic range is 75dB. I have seen some transmitter architechture, it always uses external Power Ampli ...
smartchi 发表于 2009-10-9 11:08
The dynamic range = 75dB does consist of this external power amplifier
Only the on-chip circuit may be not enough for the dynamic range
发表于 2010-1-28 14:44:14 | 显示全部楼层
LTE的资料也越来越多了,不知道哪个更经典些 ,选书还是很重要的
发表于 2010-6-30 14:22:55 | 显示全部楼层
推推推
GMT+8, 2025-11-4 05:16 , Processed in 0.023497 second(s), 6 queries , Gzip On, Redis On.
