查看: 4087|回复: 7
How to deal with the internal clock during DFT
发表于 2009-10-7 23:40:53 | 显示全部楼层 |阅读模式
Hi, all,
  There is an internal clock generated by the system clock. When I inserted scan chain, all the flip-flops driven by the internal clock weren't in the scan chain. It said the CK of these FF are uncontrolled. I set mixing_clock mix_clocks.
   How can i fix those problems?
   Thank you so much.
发表于 2009-10-10 20:41:16 | 显示全部楼层
我是来顶的
发表于 2009-10-21 07:51:07 | 显示全部楼层
如果RTL未freeze,修改RTL,增加mux, 用test_mode作为选择信号在test模式下将外部clk用作dft clk,在功能模式下将分频时钟用作clk; 如果代码freeze,用autofix在门级来解决这个问题。我是做dft的,有什么问题可以给我邮件一起讨论:haidongli22@yahoo.com.cn
头像被屏蔽
发表于 2009-10-21 15:24:29 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-5-26 20:17:37 | 显示全部楼层
thank you very much
发表于 2011-6-16 16:27:20 | 显示全部楼层
学习了
发表于 2011-6-22 15:28:08 | 显示全部楼层
來學習看看
发表于 2011-7-14 15:49:09 | 显示全部楼层
回复 3# creese
    请问用的是哪个工具?
GMT+8, 2025-12-14 07:32 , Processed in 0.019185 second(s), 5 queries , Gzip On, Redis On.
