查看: 5747|回复: 17
A Highly Linear Broadband CMOS LNA Employing Noise and Distortion Cancellation
发表于 2009-10-1 08:22:43 | 显示全部楼层 |阅读模式
Abstract
broadband inductorless low-noise amplifier (LNA)
design that utilizes simultaneous noise and distortion cancellation
is presented. Concurrent cancellation of the intrinsic third-order
distortion from individual stages is exhibited with the commongate
and common-source cascade. The LNA IIP.. is then limited
by the second-order interaction between the common source and
common gate stages, which is common in all cascade amplifiers.
Further removal of this third-order distortion is achieved by incorporating
a second-order-distortion-free circuit technique in the
common gate stage. Implemented in 0.13 m CMOS technology,
this LNA achieved..16 dBm IIP.. in both the 900 MHz and 2 GHz
bands. Measurements demonstrate that the LNA has a minimum
internal gain of 14.5 dB, noise figure of 2.6 dB from 800 MHz to
2.1 GHz while drawing 11.6 mA from 1.5 V supply voltage.
Index Terms桞roadband LNA, distortion cancellation, noise
cancellation, volterra series analysis.
A Highly Linear Broadband CMOS LNA Employing Noise and Distortion Cancellation.pdf
922.01 KB, 下载次数: 170 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-12-18 00:32:55 | 显示全部楼层
最近找Broadband LNA主題~多謝分享
发表于 2011-5-20 13:59:13 | 显示全部楼层
thank you very much
发表于 2012-9-19 23:05:58 | 显示全部楼层
下来看看是不是所需要的
发表于 2012-10-8 18:26:19 | 显示全部楼层
这个很好  卡卡
发表于 2013-7-25 04:15:07 | 显示全部楼层
良好的設計數據........
发表于 2014-9-2 14:16:47 | 显示全部楼层
好东西,谢谢分享
发表于 2014-9-2 14:45:28 | 显示全部楼层
好东西
发表于 2014-9-2 22:06:23 | 显示全部楼层
非常感謝 ~~~~
发表于 2015-4-22 20:27:06 | 显示全部楼层
A thesis of CMOS LNA design
GMT+8, 2025-11-9 06:44 , Processed in 0.018280 second(s), 5 queries , Gzip On, Redis On.
