楼主: mryu
Qualcomm: WCDMA and cdma2000 Comparison
发表于 2007-11-28 10:59:12 | 显示全部楼层
Table of Contents
SUMMARY................................................................................................................................ 1
Table of Contents....................................................................................................................... 2
Introduction................................................................................................................................ 3
Major Conceptual Similarities..................................................................................................... 3
Major Differences...................................................................................................................... 3
Chip Rate................................................................................................................................ 4
Migration from existing technologies................................................................................... 4
Numerology........................................................................................................................ 4
Eb/No Requirement............................................................................................................. 4
Overall Capacity.................................................................................................................. 5
Out of Band Emissions........................................................................................................ 5
Summary of Chip Rate Comparison.................................................................................... 6
Forward Link Pilot Structure................................................................................................... 6
Basic Fundamental Approaches.......................................................................................... 6
Dedicated Time Multiplexed Pilot (DTMP).......................................................................... 6
Common Code Multiplexed Pilot (CCMP)........................................................................... 7
Base Station Synchronization.................................................................................................. 8
Base Station Acquisition and Detection............................................................................... 9
Terminal Battery Life Characteristics...................................................................................... 9
Dedicated Mode................................................................................................................ 10
Idle Mode.......................................................................................................................... 10
Inter-Frequency Hard Handoff and Hierarchical Cell Structure (HCS)................................. 11
Frame Length........................................................................................................................ 11
Differences in Deployment Possibilities................................................................................... 12
Benefits of 1.25 MHz Deployment Option........................................................................... 13
Deployment in 2x 5 MHz.................................................................................................. 13
Band Packing and Band Planning...................................................................................... 13
Benefits of Multi-Carrier Spreading Option.......................................................................... 14
Appendix 1 – Numerology....................................................................................................... 16
Appendix 2 - Overall Capacity................................................................................................. 18
Appendix 3 - Emission Limits.................................................................................................. 21
Filter Characteristics.............................................................................................................. 21
Output Power Level.............................................................................................................. 21
Impact on Forward Link Capacity..................................................................................... 23
Appendix 4 – cdma2000 Inter-frequency Hard Handoff procedures....................................... 26
Inter-frequency Search Procedure......................................................................................... 26
Minimizing Impact of Search Excursion on Current Frame................................................... 27
Off-Line Pilot Searching.................................................................................................... 27
Increasing Symbol Energy of Current Frame..................................................................... 27
Forward Link Power Control during Search Visit.............................................................. 27
Reverse Link Power Control during Search Visit............................................................... 28
Search excursion position within a frame............................................................................. 29
Hard Handoff Failure Recovery........................................................................................ 29
References................................................................................................................................ 30
IntroductionDevelopment of the 3G CDMA systems for IMT-2000 is oriented towards a wider set of services than provided in second generation cellular systems. Both WCDMA and cdma2000 are to provide these new services. Since currently deployed CDMA systems have been the source of many of the new ideas behind using CDMA for cellular and PCS applications, there are naturally similarities between the two RTTs. Furthermore, harmonization activities have brought the RTT contributions even closer. So, first we list similarities and then discuss more extensively the residual differences, which have not yet been converged by the continuing harmonization efforts. The similarities are mainly at a functional and conceptual level. Many of the technical details such as nomenclature, timing, and precise parameters are different, due to parallel on-going standardization efforts. This is true for both the physical layer and lower layers.
Both cdma2000 and WCDMA were designed to meet the ITU IMT-2000 Requirements in terms of data rates, enhanced spectrum efficiency, and range of operating environments. New frequency bands have been allocated in many parts of the world to deploy IMT-2000 systems. The WCDMA system is mainly targeted for deployment in new (green field) spectrum. By contrast, cdma2000 was designed to be deployed both in existing bands and new spectrum. This lead to some of the conceptual differences in terms of spreading method and chip rates discussed further in this document.
Major Conceptual SimilaritiesThis list pertains to functional and conceptual similarities between the two CDMA IMT-2000 proposals.  It should be noted that while the concepts are similar, the details of the physical layer are different. This is mainly due to separate standardization efforts. However, since many of the underlying physical layer concepts are identical, many of the details can be harmonized without impacting the system performance or integrity.
Similarities in both systems include:
·      Coherent forward and reverse link
·      Fast power control on forward link as well as reverse link.
·      Variable length orthogonal Walsh sequences used for forward link channelization
·      Complex QPSK spreading on both forward and reverse link
·      Convolutional codes used as baseline (identical polynomials)
·      Parallel Turbo codes for higher data rates
·      Orthogonal Walsh functions separating the users parallel code channels on the reverse link
·      Variable spreading factor to achieve higher data rates
·      Non orthogonal reverse link based on PN scrambling codes
·      Mobile Assisted inter-frequency hard handoff procedures
·      Variable rate operation with blind rate estimation for simple services (e.g. voice)
·      Continuous reverse link operation
Major DifferencesThe following items are major physical layer differences being addressed for future convergence. There are many other differences in the details of the physical layer parameters and procedures. The list below addresses some of the major differences in the physical layer concepts and parameters affecting harmonization of the two systems.
Table 1: Major Physical Layer Differences between WCDMA and cdma2000
WCDMA
cdma2000
Chip rate
4.096 Mcps
3.6864 Mcps
Forward link pilot for channel estimation
TDM dedicated pilot
CDM common pilot
发表于 2010-1-24 18:51:02 | 显示全部楼层
okokokok
发表于 2010-2-2 07:30:04 | 显示全部楼层
发表于 2010-2-2 11:27:03 | 显示全部楼层
thanks. But it is little old
发表于 2010-2-6 08:54:00 | 显示全部楼层
zhichi
发表于 2010-2-9 11:12:34 | 显示全部楼层
kankan
发表于 2010-5-3 19:02:32 | 显示全部楼层
thanks!
发表于 2010-5-8 16:08:54 | 显示全部楼层
dingqi
发表于 2010-5-23 22:51:22 | 显示全部楼层
thanks for sharing
发表于 2011-2-2 02:02:06 | 显示全部楼层
thanks alot
GMT+8, 2025-12-30 09:24 , Processed in 0.066922 second(s), 4 queries , Gzip On, Redis On.
