查看: 4823|回复: 18
Brushless DC Motor Controller
发表于 2009-9-28 13:05:37 | 显示全部楼层 |阅读模式
The MC33033 is a high performance second generation, limited
feature, monolithic brushless dc motor controller which has evolved
from ON Semiconductor's full featured MC33034 and MC33035
controllers. It contains all of the active functions required for the
implementation of open loop, three or four phase motor control. The
device consists of a rotor position decoder for proper commutation
sequencing, temperature compensated reference capable of supplying
sensor power, frequency programmable sawtooth oscillator, fully
accessible error amplifier, pulse width modulator comparator, three
open collector top drivers, and three high current totem pole bottom
drivers ideally suited for driving power MOSFETs. Unlike its
predecessors, it does not feature separate drive circuit supply and
ground pins, brake input, or fault output signal.
Included in the MC33033 are protective features consisting of
undervoltage lockout, cycle-by-cycle current limiting with a
selectable time delayed latched shutdown mode, and internal thermal
shutdown.
Typical motor control functions include open loop speed, forward or
reverse direction, and run enable. The MC33033 is designed to operate
brushless motors with electrical sensor phasings of 60°/300° or
120°/240°, and can also efficiently control brush dc motors.
MC33033-D.pdf
352.68 KB, 下载次数: 79 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-10-10 19:55:12 | 显示全部楼层
发表于 2010-2-5 03:51:33 | 显示全部楼层
Take a look, thanks.
发表于 2010-2-9 11:26:25 | 显示全部楼层
谢谢 啊
发表于 2010-3-30 09:29:52 | 显示全部楼层
谢谢 帮助
发表于 2010-4-14 22:38:22 | 显示全部楼层
session19
发表于 2010-4-14 22:42:05 | 显示全部楼层
session19
发表于 2010-4-14 22:43:38 | 显示全部楼层
session19
发表于 2010-4-14 22:47:52 | 显示全部楼层
session19
发表于 2010-4-14 22:48:54 | 显示全部楼层
session19
GMT+8, 2025-12-15 13:19 , Processed in 0.148671 second(s), 6 queries , Gzip On, Redis On.
