查看: 3905|回复: 12
[原创] 如何去读一个DATASHEET
发表于 2009-9-19 10:29:35 | 显示全部楼层 |阅读模式
如何去读一个DATASHEET
读数据手册,这是个能力问题
如何去读一个DATASHEET.pdf
325.57 KB, 下载次数: 50 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-9-19 13:53:55 | 显示全部楼层
谢谢了
发表于 2009-9-20 22:33:20 | 显示全部楼层
谢谢了,学习一下!
发表于 2009-9-21 19:22:26 | 显示全部楼层
谢谢,
发表于 2009-9-22 06:36:29 | 显示全部楼层
大力支持好东西
发表于 2010-11-9 18:35:25 | 显示全部楼层
谢谢了!
发表于 2010-11-10 06:28:45 | 显示全部楼层
thanks
发表于 2010-11-10 08:42:25 | 显示全部楼层
学习了。。。。。。。
发表于 2010-11-10 10:14:16 | 显示全部楼层
Gives the keyboard input focus to this widget (or its focus proxy) if this widget or one of its parents is the active window. The reason argument will be passed into any focus event sent from this function, it is used to give an explanation of what caused the widget to get focus. If the window is not active, the widget will be given the focus when the window becomes active.
First, a focus out event is sent to the focus widget (if any) to tell it that it is about to lose the focus. Then a focus in event is sent to this widget to tell it that it just received the focus. (Nothing happens if the focus in and focus out widgets are the same.)
发表于 2010-11-14 23:40:29 | 显示全部楼层
这个也有教程
GMT+8, 2025-12-14 07:53 , Processed in 0.023409 second(s), 11 queries , Gzip On, Redis On.
