查看: 4055|回复: 9
vcs 的一个bug
发表于 2009-9-11 17:05:17 | 显示全部楼层 |阅读模式
在跑仿真的时候,当从一个RAM中读取数据时,发现数据不对。
仔细检查了写入的数据和地址,没错。
但是读出相应地址的数据时,会出错,数据不符合写入的值。
后来在always block里的读操作后面加了一个display的语句,结果读出的数据就对了。
这是否跟vcs仿真算法有关?
怀疑这是vcs的一个bug,不知是否如此。
可有哪位大牛出来指点指点?介绍个vcs相关的文档看看,理解理解vcs仿真的process。多谢多谢
发表于 2009-9-11 17:31:07 | 显示全部楼层
It isn't very surpirise that you found only A vcs bug. I found  A LOT and reported them to synopsys support centrum.
However, They fixed bugs quite quickly and vcs is the best simulator for systemverilog I've used.
 楼主| 发表于 2009-9-11 18:31:40 | 显示全部楼层
原帖由 humann 于 2009-9-11 17:31 发表 It isn't very surpirise that you found only A vcs bug. I found A LOT and reported them to synopsys support centrum. However, They fixed bugs quite quickly and vcs is the best simulator for systemver ...
i m rookie,bugs visit rookie not much...
so, bugs' lover,
have you ever encountered the problem that i mentioned?
发表于 2009-9-11 23:00:16 | 显示全部楼层
same with you. you should email vcs support.He'll give your an answer.
发表于 2010-1-29 14:00:49 | 显示全部楼层
which version did you used?
发表于 2010-1-30 12:34:15 | 显示全部楼层
侃侃什么bug
发表于 2010-1-30 12:36:42 | 显示全部楼层
反映上去,
发表于 2010-1-30 12:38:31 | 显示全部楼层
厉害!
发表于 2010-1-30 12:42:07 | 显示全部楼层
牛xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
发表于 2010-2-5 23:59:28 | 显示全部楼层
9# whxqq
bug是多,不过软件做的还是很好的 忍了
GMT+8, 2025-12-12 15:12 , Processed in 0.023149 second(s), 6 queries , Gzip On, Redis On.
