查看: 6469|回复: 15
ADS 2009 Update 1 -- Product Version Release
发表于 2009-9-9 09:16:16 | 显示全部楼层 |阅读模式
ADS 2009 Update 1 delivers new features and improved value for all ADS users with special focus on MMIC and RF Module design, including enhancing the complete flow to manufacturing. These new features eliminate the time to integrate disparate point tools from numerous vendors (e.g. 3D EM and Layout). This, along with the new simplified ADS product structure, can provide significant license cost savings for the MMIC/Module design. Learn more about the new ADS product structure.
New X-Parameter Generator
X-parameter models are fast, cascadable, nonlinear behavioral models that accurately account for frequency mixing and impedance mismatch. X-parameters fulfill a long standing need from the high-frequency design community for nonlinear behavioral models that can be created from measurement or simulation with the same speed and convenience as the well known linear S-parameters. The X-Parameter Generator enables MMIC, RF-SIP and RF module design houses to provide their customers with an accurate, pre-prototype model of their nonlinear devices (e.g. power amplifiers, front-end modules and transceivers) to further enable concurrent design and secure early design wins. Learn more about X-parameters.
Enhanced Integrated 3D EM Analysis
3D parameterized components from Electromagnetic Professional (EMPro) can now be used for swept simulation and optimization in the ADS Finite Element simulator (EMDS G2). Custom parameterized 3D components can be created in EMPro’s solid modeling environment and then placed in ADS layout. EMDS G2 can then simulate the 3D component together with the surrounding layout and even co-simulate with ADS circuit simulators. This powerful combination will detect chip/module/package/board interface issues much earlier in the design process. Learn more about EMPro.
Complete Flow to Manufacturing
•Enhanced and customized GaAs foundry qualified, approved and supported Process Design Kits (PDKs) that include Calibre & Assura DRC support and new MMIC toolbars
•MMIC toolbars enable the full set of layout editing commands customized for foundry-specific PDKs, including single-button commands to: convert traces to transmission-line elements; edit transmission-line elements (stretch, tap, split, move to layer); automatically insert vias; automatically create multi-layer metal traces; synchronize layout back to the schematic; check design differences between layout and schematic; show nodal and physical connectivity; and launch the 3D layout viewer and DRC engine
•Multi-technology PDK support provides easier management of interconnect layers and automation of MMIC/Module assembly for 3D EM simulation
•ADS Desktop LVS, a new layout vs. schematic design checker that requires no setup and catches errors early in the design cycle
•Calibre LVS integration supplements existing support for Calibre & Assura DRC
Learn more about Agilent EEsof EDA Foundry Partners and Industry Resources.
New Optimization Cockpit
The optimization cockpit is a new interactive environment (cockpit) that enables you to enter multiple optimization variables and goals and interactively tune and control the progress of the optimizer. This enables you to achieve the best performance while gaining design insights on the behavior of the optimized variables versus the goals. At a glance, you can identify which variables are constrained at the limits of their allowed ranges and adjust these limits to allow the optimizer to achieve better results. You can also observe the Pareto of which goals dominate the error function to provide guidance on setting the goal weightings. View a video demo of the new Optimization Cockpit in ADS 2009 Update 1.
Signal Integrity Channel Simulation and Eye Diagram Statistics
ADS 2009 Update 1 adds the following capabilities to the Channel Simulator in the W2302 Transient Convolution Element:
•Decision feedback equalizer (DFE) and Feed-forward equalizer (FFE) support with automatic tap optimization
•Statistical simulation mode
•Bit-error rate (BER) contour and bathtub display
•New eye mask utility with automatic violation checker
•Enhanced crosstalk modeling
•I/O Buffer Information Specification (IBIS) Emitter-coupled logic (ECL) Models
•New Time Domain Reflectometry (TDR) Front Panel tool
Learn more about ADS for signal integrity.
When Will ADS 2009 Update 1 Be Available?
ADS 2009 Update 1 will be demonstrated at public events and tradeshows worldwide beginning with the MTT-S International Microwave Symposium (IMS) in Boston the week of June 9th. For more detail on IMS 2009, refer to the IMS 2009: Technical Program and Workshops.
Software for customer evaluation will be available after the ADS 2009 Update 1 Early Access/Beta program which will begin in June of 2009. Product shipments are expected by the end of the summer.
Looking for another version? View other ADS Product Versions.
* X-parameter is a trademark of Agilent Technologies.
[ 本帖最后由 suiwinder 于 2009-9-9 09:18 编辑 ]
发表于 2009-9-9 10:53:07 | 显示全部楼层
很强大的软件,希望能有下载。
发表于 2010-3-28 17:35:54 | 显示全部楼层
good software, thanks for your information
发表于 2010-3-30 20:16:43 | 显示全部楼层
ADS功能强大,从离散的射频/微波模块到用于通信和航天/国防的集成MMIC,都应对得来。
发表于 2010-6-22 14:30:11 | 显示全部楼层
好是好,哪里下载
发表于 2010-6-24 10:01:22 | 显示全部楼层
下载了但不能破解,还是不能用
发表于 2010-6-25 20:46:24 | 显示全部楼层
下载地址呢
发表于 2010-6-26 10:04:20 | 显示全部楼层
发表于 2010-7-16 21:49:06 | 显示全部楼层
上安捷伦网站下载,就是没有破解,期待中。
发表于 2010-7-23 14:33:36 | 显示全部楼层
thx for sharing
GMT+8, 2025-12-22 12:46 , Processed in 0.025120 second(s), 7 queries , Gzip On, Redis On.
