查看: 15841|回复: 56
知名芯片公司招聘视频类设计验证职位
发表于 2009-9-2 15:36:39 | 显示全部楼层 |阅读模式
Senior Design Engineer for Video Codec
Preferred Experience:
Major in EE and have Master degree or higher
3 years beyond working experience on ASIC design
Must have strong background on video encoding/decoding algorithms
Must be proficient in Verilog coding, debugging and modeling
Must be skilled in ASIC design flow, such as synthesis, DFT, timing analysis, ECO etc.
Must be skilled in mainstream EDA tools for design and simulation such as ncsim/vcs, RC/DC, PT, Formality/LEC and DFT.
Must be familiar with verification methodologies for from block level to SoC level.
Should be familiar with shell/perl/tcl programming in linux OS.
Should be familiar with P&R and Manufacture tech.
Good English hearing, speaking, reading and writing capabilities.
Will be a big plus if having tapeout experience.
Will be a plus if having C/C++, matlab experience
Senior Design Verification Engineer for Video Codec
Major in CS or EE and have Master degree or higher
3 years beyond working experience on ASIC design verification
Must be proficient in C++ programming and debugging in Linux and Windows platforms. Know well about SW engineering.
Must be experienced in various verification methodologies from block level to SoC level, and familiar with corresponding tools.
Must be skillful in shell/perl/tcl/Makefile programming in linux OS.
Should have adequate ASIC design knowledge and be able to debug RTL codes using corresponding tools
工作地点:上海
有兴趣的可MSN联系
rongchris@hotmail.com
发表于 2009-9-2 22:59:06 | 显示全部楼层
为了挣钱顶楼主
 楼主| 发表于 2009-9-3 10:02:10 | 显示全部楼层
谢谢你了
 楼主| 发表于 2009-9-7 10:29:52 | 显示全部楼层
新的星期,新的开始,大家努力~
发表于 2009-9-7 21:26:49 | 显示全部楼层
day day up
good good study
 楼主| 发表于 2009-9-8 09:38:04 | 显示全部楼层
thank you~
发表于 2009-9-8 11:22:52 | 显示全部楼层
第一个职位要求好高
应该有20W/Y吧?
发表于 2009-9-8 11:24:10 | 显示全部楼层
这个,ECO就那个了吧~~~~
哎~~~~不会
发表于 2009-9-8 21:53:38 | 显示全部楼层
职位要求好高
 楼主| 发表于 2009-9-10 11:40:02 | 显示全部楼层
呵呵~要求一开始都高的,现在都有一定程度的降低,不过技术方面还是要都会的,只是年限和学历放宽了。
另有一个新的职位急招~
Sr/MTS ASIC Design/Integration Engineer___GNB Project
PREFERRED EXPERIENCE:
MSEE or PhD and CGPA of 8.0 out of 10.0 or higher with minimum 2-3 years of ASIC design and integration experience is required.
Familiar with complex high speed ASIC Design process.
Relevant experience in Graphics, Memory Controller (DDR, DDR2, DDR3), Video, Microprocessor Design, SOC design is a plus.
Relevant experience in bus protocol USB/PCI/PCIE design is a plus.
Relevant experience in chip level design/integration, DFT, memBIST, Memory Compiler, STA is a plus.
Strong logic design, verification and debugging skills.
Exposure to Digital systems and VLSI design, Computer Architecture, Computer Arithmetic, and C/C++ programming languages, CMOS transistors and circuits is optional.
-     Good communications skills and ability and desire to work as a team player are a must.
重视integration的能力和经验啊
GMT+8, 2025-9-13 08:53 , Processed in 0.031479 second(s), 7 queries , Gzip On, Redis On.
