查看: 18791|回复: 44
TI DM365 HD 达芬奇视频处理芯片Ds及开发板线路
发表于 2009-8-24 10:59:31 | 显示全部楼层 |阅读模式
特性
    High-Performance Digital Media System-on-Chip (DMSoC)
      216-, 270-, 300-MHz ARM926EJ-S Clock Rate
    • Fully Software-Compatible With ARM9™
    ARM926EJ-S™ Core
      Support for 32-Bit and 16-Bit (Thumb® Mode) Instruction Sets DSP Instruction Extensions and Single Cycle MAC ARM® Jazelle® Technology
    • EmbeddedICE-RT Logic for Real-Time Debug
    ARM9 Memory Architecture
    • 16K-Byte Instruction Cache
    • 8K-Byte Data Cache32K-Byte RAM 16K-Byte ROM
    • Little Endian
  • Two Video Image Co-processors (HDVICP, MJCP) Engines
    • Support a Range of Encode and Decode Operations
    • H.264, MPEG4, MPEG2, MJPEG, JPEG, WMV9/VC1
    Video Processing Subsystem
      Front End Provides:
      • HW Face Detect EngineHardware IPIPE for Real-Time Image Processing
          Resize Engine
          • Resize Images From 1/16× to 8×
          • Separate Horizontal/Vertical Control
          • Two Simultaneous Output Paths
      • IPIPE Interface (IPIPEIF)
      • Image Sensor Interface (ISIF) and CMOS Imager Interface
      • 16-Bit Parallel AFE (Analog Front End) Interface Up to 120 MHzGlueless Interface to Common Video Decoders
      • BT.601/BT.656/BT.1120 Digital YCbCr 4:2:2 (8-/16-Bit Module
      • Histogram Module
      • Lens distortion correction module (LDC)
      • Hardware 3A statistics collection module (H3A)
    • Back End Provides:
      • Hardware On-Screen Display (OSD)
      • Composite NTSC/PAL video encoder output
      • 8-/16-bit YCC and Up to 24-Bit RGB888 Digital Output
      • 3 DACs for HD Analog Video Output
      • LCD Controller
      • BT.601/BT.656 Digital YCbCr 4:2:2 (8-/16-Bit) Interface
  • Analog-to-Digital Convertor (ADC)
  • Power Management and Real Time Clock Subsystem (PRTCSS)
    • Real Time Clock
  • 16-Bit Host-Port Interface (HPI)
  • 10/100 Mb/s Ethernet Media Access Controller (EMAC) - Digital Media
    • IEEE 802.3 Compliant
    • Supports Media Independent Interface (MII)
    • Management Data I/O (MDIO) Module
    Key Scan
  • Voice CodecExternal Memory Interfaces (EMIFs)
    • DDR2 and mDDR SDRAM 16-bit wide EMIF With 256 MByte Address Space (1.8-V I/O)
    • Asynchronous16-/8-bit Wide EMIF (AEMIF)
      • Flash Memory Interfaces
        • NAND (8-/16-bit Wide Data)
        • 16 MB NOR Flash, SRAM
        • OneNAND(16-bit Wide Data)
  • Flash Card Interfaces
    • Two Multimedia Card (MMC) / Secure Digital (SD/SDIO)
    • SmartMedia/xD
  • Enhanced Direct-Memory-Access (EDMA) Controller (64 Independent Channels)USB port with Integrated 2.0 High-Speed PHY that Supports
    • USB 2.0 High-Speed DeviceUSB 2.0 High-Speed Host (mini-host, supporting one external device)
    • USB On The Go (HS-USB OTG)
  • Four 64-Bit General-Purpose Timers (each configurable as two 32-bit timers)
  • One 64-Bit Watch Dog Timer
  • Two UARTs (One fast UART with RTS and CTS Flow Control)Five Serial Port Interfaces (SPI) each with two Chip-Selects
  • One Master/Slave Inter-Integrated Circuit (I2C) Bus™One Multi-Channel Buffered Serial Port (McBSP)
    • I2S
    • AC97 Audio Codec Interface
    • S/PDIF via Software
    • Standard Voice Codec Interface (AIC12)
    • SPI Protocol (Master Mode Only)
    • Direct Interface to T1/E1 Framers
    • Time Division Multiplexed Mode (TDM)
    • 128 Channel Mode
  • Four Pulse Width Modulator (PWM) Outputs
  • Four RTO (Real Time Out) Outputs
  • Up to 104 General-Purpose I/O (GPIO) Pins (Multiplexed with Other Device Functions)Boot Modes
      On-Chip ARM ROM Bootloader (RBL) to Boot From NAND Flash, MMC/SD, UART, USB, SPI, EMAC, or HPI
    • AEMIF (NOR and OneNAND)
  • Configurable Power-Saving Modes
  • Crystal or External Clock Input (typically 19.2 Mhz, 24 MHz, 27 Mhz or 36 MHz)
  • Flexible PLL Clock GeneratorsDebug Interface Support
    • IEEE-1149.1 (JTAG™) Boundary-Scan-Compatible
    • ETB (Embedded Trace Buffer) with 4K-Bytes Trace Buffer memory
    • Device Revision ID Readable by ARM
  • 338-Pin Ball Grid Array (BGA) Package (ZCE Suffix), 0.65-mm Ball Pitch
  • 65nm Process Technology
  • 3.3-V and 1.8-V I/O, 1.2-V/ 1.35-V Internal
[ 本帖最后由 xswfly 于 2009-8-24 11:00 编辑 ]
DM365_Schematics.pdf
539.81 KB, 下载次数: 287 , 下载积分: 资产 -2 信元, 下载支出 2 信元
tms320dm365.pdf
1.55 MB, 下载次数: 227 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-8-28 15:27:58 | 显示全部楼层
DM365开发包
哪里能下载开发包?
发表于 2009-8-28 15:33:01 | 显示全部楼层
希望能够和使用DM365的朋友交流
发表于 2009-8-28 22:47:55 | 显示全部楼层
非常好的资料
发表于 2009-9-8 10:04:38 | 显示全部楼层
非常好,很有帮助
非常好,很有帮助
发表于 2009-9-20 01:16:26 | 显示全部楼层
thank a lot
发表于 2009-10-5 22:02:33 | 显示全部楼层
谢谢,下来看看
发表于 2009-10-7 14:29:27 | 显示全部楼层
謝謝你的分享
发表于 2009-11-12 17:13:39 | 显示全部楼层
1# xswfly dddddddddddddd
发表于 2009-11-18 17:05:00 | 显示全部楼层
好东西,谢谢分享
1# xswfly
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-10 18:49 , Processed in 1.008882 second(s), 6 queries , Gzip On, Redis On.
