查看: 4565|回复: 2
medici2003使用问题
发表于 2009-8-20 21:36:32 | 显示全部楼层 |阅读模式
我在RedHat9.0按照说明安装了medici2003,可是运行lmgrd时出现:
Incorrectly built binary which accesses errno, h_errno or _res directly. Needs to be fixed.
17:20:38 (tmald) FLEXlm version 7.2i
17:20:38 (tmald) cannot establish lock - exiting (file: /usr/tmp/locktmald, errno: 11)
17:20:38 (lmgrd) Started tmald (internet tcp_port 32807 pid 4769)
17:20:38 (lmgrd) license daemon: lost all connections
17:20:38 (lmgrd) This is an internal error.
lmgrd will now
17:20:38 (lmgrd) attempt to re-establish contact with other daemons.
17:20:38 (lmgrd) Starting vendor daemons ...
可是没有发现有locktmald程序,真是奇怪!
 楼主| 发表于 2009-8-20 21:38:19 | 显示全部楼层
运行medici,出现:
[root@localhost ~]# medici
dirname: 参数太少
请尝试执行‘dirname --help’来获取更多信息。
dirname: 参数太少
1
MEDICI (TM)
Version V-2003.12-0
System K (PC: Linux)
Copyright (C) 1991-2003
Synopsys, Inc.
All Rights Reserved
MEDICI is a trademark of Synopsys, Inc.
19-Aug-2009 17:36:06
Enter the input file name (press return for interactive mode)
File name: /usr/tcad/medici2003/examples/medici/bipgum0
*** Warning your copy of MD will expire on 1-jan-0 ***
1 copy of MD locked (expires 1-jan-0)....
**************************** Program Configuration ****************************
* Programmable Device AAM
available for use
* Circuit Analysis AAM
available for use
* Lattice Temperature AAM
available for use
* Heterojunction Device AAM:
available for use
* Trapped Charge AAM
available for use
* Anisotropic Material AAM :
available for use
* Optical Device AAM
available for use
* Maximum Nodes Available
10000
* Configuration Parameter
10000
* Approximate Number of Nodes Available for:
2-carrier solutions
10000
2-carrier + lat. temp. :
5727
TMA MEDICI Template File for BJT Gummel Characteristics
Error number 1003 detected in line number
10
The parameter name is invalid.
string: @MODELS
Error number 1135 detected in line number
21
A character expression has been used in place of a numerical or
logical value with a numerical function, arithmetic operator, or
logical operator. Character expressions can only be used with
relational operators (<, <=, >, >=, =, ^=), logical functions
(NTYPE, LTYPE, CTYPE), and conversion functions (NVAL, LVAL).
string: @VB0
21
string: @VC0
26
string: @VB0
26
string: @VBSTEP
26
string: @NBSTEP
26
string: @OUTFS
30
string: @VB0+(@NBSTEP
31
string: @VB0+0.05*(@VBMAX
32
string: @VB0+0.01*(@VBMAX
35
string: @VB0
35
string: @VBMAX
37
string: @XLOC
39
string: @XLAB
40
string: @XLAB
*** END MEDICI ***
发表于 2018-4-24 22:54:14 | 显示全部楼层
遇到了同样的问题 不知怎么解决
GMT+8, 2025-12-26 15:58 , Processed in 0.016629 second(s), 5 queries , Gzip On, Redis On.
