查看: 10384|回复: 17
[求助]为什么cadenceic610的帮助文档无法打开!
发表于 2009-7-14 23:26:11 | 显示全部楼层 |阅读模式
在openSUSE11.1中,在candenceic virtuoso@610主界面启动后,如下:
COPYRIGHT © 1992-2006  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
          © 1992-2006  UNIX SYSTEMS Laboratories INC.,
                         Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
          RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Program:        @(#)$CDS: virtuoso.exe version 6.1.0 10/10/2006 14:09 (cds126047) $
Sub version:        sub-version IC6.1.0.243 (32-bit addresses)
Loading geView.cxt
Loading LVS.cxt
Loading layerProc.cxt
Loading xlUI.cxt
Loading auCore.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ams.cxt
END OF SITE CUSTOMIZATION
*WARNING* obShowTag for tool "text", tag "hiNoHelp" (version "") failed, status 20 = obcServerCantStart
*Warning* No help found for help symbol hiNoHelp
点击菜单help->下面的cadence documentation,弹出提示框:
some cadenceonline documentation files are missing or can not be opened duo to anerror.
to start the cadence documentation systme, type cdsdoc at asystem prompt
同时在终端下出现如下:
/home/eda/ic610/tools/cdsdoc/bin/obServer: error while loading shared libraries: libnsl.so.1: cannot open shared object file: No such file or directory
obApi: unable to contact /home/eda/ic610/tools/bin/obServer.
在终端系统提示符下,运行如下命令,结果如下:
***@***:~> cdsdoc
/home/eda/mmsim61/tools/jre/bin/java: error while loading shared libraries: libpthread.so.0: cannot open shared object file: No such file or directory
***@***:~> cdsbook
/home/eda/ic610/tools/jre/bin/java: error while loading shared libraries: libpthread.so.0: cannot open shared object file: No such file or directory
请问那位大虾帮忙解决一下,谢谢!
[ 本帖最后由 lishyg 于 2009-7-16 15:14 编辑 ]
发表于 2009-8-24 23:46:30 | 显示全部楼层
Thank You
Hey Hope this works file. Would let you know.
发表于 2010-4-6 18:21:15 | 显示全部楼层
我的缺少java库,不知道怎么添加
发表于 2010-4-14 22:58:40 | 显示全部楼层
换个浏览器试试
发表于 2011-4-17 15:51:00 | 显示全部楼层
这是在edaboard上面找到的解决方案:
Originally Posted by st01liyp
I have solved this problem, spend me a lot of time:
there are three reason we don't get cdsdoc working:
1: java want to set LD_ASSUME_KERNEL to current kernel version
2: obServer want LD_ASSUME_KERNEL set to null
3: https need libstdc++-libc6.1-1.so.2
since I am using ubuntu, so this solution is base on ubuntu.
1.edit $INST_DIR/mmsim610/tools/bin/cdsdoc and $INST_DIR/ic610/tools/bin/cdsdoc like this:
if [ $PLATFORM = "lnx86" ]; then
if [ $ARCH = "x86_64" ]; then
# AMD Opteron RHEE3.0
#LD_ASSUME_KERNEL=2.4.19
LD_ASSUME_KERNEL=2.6.27
export LD_ASSUME_KERNEL
else
#Standard x86 systems
LD_ASSUME_KERNEL=2.2.5
fi
fi
2.edit $INST_DIR/mmsim610/tools/bin/obServer and $INST_DIR/mmsim610/tools/bin/obServer like this
# LD_ASSUME_KERNEL=2.4.19
LD_ASSUME_KERNEL=
3. download compat-libstdc++-296-2.96-135.i386.rpm
tar zxf compat*tgz
sudo apt-get install alien
cd usr/lib
sudo cp libstdc++-2-libc6.1-1-2.9.0.so /lib32/libstdc++-libc6.1-1.so.2
now cdsdoc works fine.
Originally Posted by skiptoo
I guess you must have a x86_64 arch
For user who uses a i386 arch,just edit the else block in both cdsdoc and obServer file like this
#LD_ASSUME_KERNEL=2.6.27
else
#LD_ASSUME_KERNEL=2.2.5
fi
fi
and then
sudo cp libstdc++-2-libc6.1-1-2.9.0.so /usr/lib/libstdc++-libc6.1-1.so.2
Thanks a lot "st01liyp", hope everyone good luck! My cdsdoc works just fine!
BTW:My OS is Ubuntu 8.10 with kernel 2.6.27-13
i386的电脑参考前后两个人的回复。
x86-64的电脑 参考前面那个。
发表于 2011-4-18 13:53:46 | 显示全部楼层
good .
发表于 2011-4-24 21:05:32 | 显示全部楼层
我也碰到了同样的问题,先看看你的建议能否有用,谢谢!
发表于 2011-5-2 18:43:20 | 显示全部楼层
DDADSa
发表于 2014-4-27 15:12:49 | 显示全部楼层
没有解决问题啊
发表于 2014-4-28 00:10:25 | 显示全部楼层
great info
GMT+8, 2025-12-27 10:14 , Processed in 0.233826 second(s), 7 queries , Gzip On, Redis On.
