查看: 11710|回复: 59
Design of Low-Voltage CMOS Switched-Opamp Switched-Capacitor Systems
发表于 2009-7-13 13:52:53 | 显示全部楼层 |阅读模式
Product Details
  • Hardcover: 210 pages
  • Publisher: Springer; 1 edition (June 30, 2003)
  • Language: English
  • ISBN-10: 1402074662
  • ISBN-13: 978-1402074660
Product Description
Demand for low-power low-voltage integrated circuits (ICs) has rapidly grown due to the increasing importance of portable equipment in all market segments including telecommunications, computers, and consumer electronics. The need for low-voltage ICs is further motivated by CMOS technology scaling that requires low supply voltages for device reliability. On the other hand, switched-capacitor (SC) circuits, which have been well known for high accuracy and low distortion, have also become increasingly attractive for low-voltage, low-power, and even high-frequency applications. Switched-opamp (SO) technique has been proposed to enable SC circuits to operate with a single 1-V supply in standard CMOS processes without any clock voltage multiplier or low-threshold devices. However, the existing SO technique requires the opamps to turn off after their integrating phases and thus is not suitable for most of the switched-capacitor systems. In Design of Low-Voltage CMOS Switched-Opamp Switched-Capacitor Systems, the emphasis is put on the design and development of advanced switched-opamp architectures and techniques for low-voltage low-power switched-capacitor (SC) systems. Specifically, the book presents a novel multi-phase switched-opamp technique together with new system architectures that are critical in improving significantly the performance of switched-capacitor systems at low supply voltages:
1. A generic fast-settling double-sampling SC biquadratic filter architecture is proposed to achieve high-speed operation for SC circuits. 2. A low-voltage double-sampling (DS) finite-gain-compensation (FGC) technique is employed to realize high-resolution SD modulator using only low-DC-gain opamps to maximize the speed and to reduce power dissipation. 3. A family of novel power-efficient SC filters and SD modulators are built based on using only half-delay SC integrators. 4. Single-opamp-based SC systems are designed for ultra-low-power applications. In addition, on the circuit level, a fast-switching methodology is proposed for the design of the switchable opamps to achieve switching frequency up to 50 MHz at 1V, which is improved by about ten times compared to the prior arts. Finally, detailed design considerations, architecture choices, and circuit implementation of five chip prototypes are presented to illustrate potential applications of the proposed multi-phase switched-opamp technique to tackle with and to achieve different stringent design corners such as high-speed, high-integration-level and ultra-low-power consumption at supply voltages of 1V or lower in standard CMOS processes.
Deisgn of Low-Voltage CMOS Switched-Opamp Swicthed-Capacitor Systems.part1.rar
4 MB, 下载次数: 1052 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Deisgn of Low-Voltage CMOS Switched-Opamp Swicthed-Capacitor Systems.part2.rar
1.68 MB, 下载次数: 508 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-7-13 14:07:06 | 显示全部楼层
I scanned it very hard, eyes and hands also tire, why no appreacaition from the moderator, and my message also missing and was removed??
Dissapointed, next time I won't scan anymore.
anyway, thanks for uploaded again.
发表于 2009-7-14 12:23:14 | 显示全部楼层
:victory:
发表于 2009-7-15 18:59:43 | 显示全部楼层
发表于 2009-7-15 19:01:26 | 显示全部楼层
发表于 2009-7-15 19:04:00 | 显示全部楼层
发表于 2009-7-15 19:05:33 | 显示全部楼层
发表于 2009-7-15 19:06:55 | 显示全部楼层
发表于 2009-7-15 19:09:29 | 显示全部楼层
发表于 2009-7-15 19:11:23 | 显示全部楼层
GMT+8, 2025-12-16 02:07 , Processed in 0.026719 second(s), 10 queries , Gzip On, Redis On.
