查看: 19519|回复: 33
it is done:Ansoft Q3D Extractor..crack+full download
发表于 2009-6-18 21:01:38 | 显示全部楼层 |阅读模式
fgfg
3D/2D Parasitic Extraction for High-Performance Electronic Design                                   Q3D Extractor® is the premier 3D parasitic extraction software tool forengineers designing multi-layer boards, complex IC packages and 3Don-chip passive components. Q3D Extractor efficiently performs the 3Dand 2D electromagnetic-field simulation required for the extraction ofRLCG parameters from an interconnect structure and automaticallygenerates an equivalent SPICE sub-circuit model. These highly accuratemodels can then be used to perform signal integrity analysis to studyEM phenomena, such as crosstalk, ground bounce, interconnect delays,and ringing, and to understand the performance of high-speed electronicdesigns.
New in Q3D Extractor v8
  • New Capacitance solver in Q3D Extractor that solves for C and G due to lossy dielectrics
  • Infinite ground plane capability
  • Multiprocessing and Distributed Analysis options
  • Revised interface for 2D Extractor:
    • Improved 2D modeling
    • Simplified problem setup
    • Ability to perform discrete and interpolating frequency sweeps
    • Integrated Optimetrics™
    • Enhanced post-processing
    • New optional convergence criteria using power loss
    • Finite Conductivity Boundary added for surface roughness modeling
    • Advanced product coupling capability with Ansoft Designer® and Simplorer®
  • Frequency-dependent dielectric loss model (Djordjevic-Sarkar)
  • GDSII export
Full crack download from here..............
http://www.eetop.cn/bbs/thread-176767-1-1.html
Full book download from here................
http://www.eetop.cn/bbs/thread-94264-3-1.html
have fun and please response.......i would glad to have it.
[ 本帖最后由 gman 于 2009-6-18 21:05 编辑 ]
发表于 2009-7-7 15:20:18 | 显示全部楼层
good~~~~~~~~~~~~~~~
发表于 2009-10-29 20:20:27 | 显示全部楼层
thanks !
发表于 2009-10-29 20:31:04 | 显示全部楼层
太多了,每钱
发表于 2010-1-26 02:38:38 | 显示全部楼层
tranka
发表于 2010-1-26 02:43:08 | 显示全部楼层
thanks
发表于 2010-6-12 20:59:08 | 显示全部楼层
这个必须顶
发表于 2010-6-15 11:23:30 | 显示全部楼层
It is a nice software
发表于 2010-6-15 11:28:56 | 显示全部楼层
Thanks
发表于 2010-6-18 13:31:40 | 显示全部楼层
thanks
GMT+8, 2025-10-30 05:31 , Processed in 0.017247 second(s), 3 queries , Gzip On, Redis On.
