查看: 28978|回复: 113
最新Rail-To-Rail OPAMP(IEEE论文)
发表于 2009-6-17 17:47:20 | 显示全部楼层 |阅读模式
content:
A compact rail-to-rail output stage for CMOS operational amplifier.pdf
Low-voltage, low-power CMOS operation transconductance amplifier with rail-to-rail differential input range.pdf
CMOS op amp with fully-differential gain-enhancement.pdf
A 15mW 280MHz 80dB gain CMOS limiting logarithmic amplifier with active cascode gain–enhancement.pdf
Fast-settling CMOS operational amplifiers with negative conductance voltage gain enhancement.pdf
A high-swing 2-V CMOS operational amplifier with replica-amp gain enhancement.pdf
A low-voltage CMOS rail-to-rail operational amplifier using double p-channel differential input pairs.pdf
1-V rail-to-rail bulk-driven CMOS OTA with enhanced gain and gain-bandwidth product.pdf
Class-AB rail-to-rail CMOS analog buffer.pdf
1-V Rail-to-Rail CMOS OpAmp With Improved Bulk-Driven Input Stage.pdf
A Simple Rail-to-Rail CMOS Voltage Follower.pdf
A new low-voltage CMOS rail-to-rail balanced output current conveyor realization.pdf
1-V rail-to-rail operational amplifiers in standard CMOS technology.pdf
A 0.8V, 7spl mua, rail-to-rail inputoutput, constant Gsub m operational amplifier in standard digital 0.18spl mum CMOS.pdf
R2R-opamp.rar
4.18 MB , 阅读权限: 20 , 下载次数: 1076 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2009-6-18 23:44:19 | 显示全部楼层
超强啊!
发表于 2009-6-19 09:50:37 | 显示全部楼层
啥东东,下了看看,学习先
发表于 2009-6-20 09:25:06 | 显示全部楼层
thanks for sharing
发表于 2009-6-20 11:41:23 | 显示全部楼层
都是些不错的文章,不过有点老
发表于 2009-6-21 14:33:26 | 显示全部楼层
xiexiela
发表于 2009-6-21 14:42:03 | 显示全部楼层
很想看看,谢谢
发表于 2009-6-22 09:07:03 | 显示全部楼层
xiexie
发表于 2009-6-22 09:31:00 | 显示全部楼层
thanks for your sharing!
发表于 2009-6-23 11:58:48 | 显示全部楼层
dddddddd
GMT+8, 2025-12-28 22:04 , Processed in 0.037523 second(s), 6 queries , Gzip On, Redis On.
