查看: 3161|回复: 5
PIC 系列单片机 PICBasicPro 语言教程(英文版)
发表于 2009-6-9 13:28:17 | 显示全部楼层 |阅读模式
PICBasicPro是我用过的最方便的单片机编程语言之一;这本教材虽然是英文版的,但内容简洁易懂,对有一定英文基础的同学应该没有大碍。
介绍:The PicBasic Pro Compiler (or PBP) makes it even quicker and easierforyou to program Microchip Technology’s powerfulPICmicromicrocontrollers (MCUs). The English-like BASIC language ismucheasier to read and write than the quirky Microchip assemblylanguage.The PicBasic Pro Compiler is “BASIC Stamp II like” and hasmost of thelibraries and functions of both the BASIC Stamp I and II.Being a truecompiler, programs execute much faster and may be longerthan theirStamp equivalents.PBP is not quite as compatible with theBASIC Stamps as our originalPicBasic Compiler is with the BS1.Decisions were made that we hopeimprove the language overall. One ofthese was to add a realIF..THEN..ELSE..ENDIF instead of theIF..THEN(GOTO) of theStamps. These differences are spelled out later inthis manual.PBP defaults to create files that run on a PIC16F84-04/Pclocked at4MHz. Only a minimum of other parts are necessary: 2 22pfcapacitorsfor the 4MHz crystal, a 4.7K pull-up resistor tied to the/MCLR pin and asuitable 5- volt power supply. PICmicro MCUs other thanthe 16F84, aswell as oscillators of frequencies other than 4MHz, may beused with thePicBasic Pro Compiler.
PICBASICPROmanual.pdf
1.08 MB, 下载次数: 68 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-11-21 15:13:30 | 显示全部楼层
hen bu cuo de zi liao
发表于 2013-12-24 15:33:28 | 显示全部楼层
回复 1# orzcc
   好好学一下
发表于 2014-4-5 14:42:13 | 显示全部楼层
挺好的dddddddddd
发表于 2015-12-14 11:33:27 | 显示全部楼层
好书
发表于 2016-6-13 14:35:25 | 显示全部楼层
THANK YOU
GMT+8, 2025-12-14 15:39 , Processed in 0.023946 second(s), 7 queries , Gzip On, Redis On.
